Results 1 to 8 of 8
Thread: vt Parker globe installation trouble
    Vt Clubsport
    May 2009
    Default vt Parker globe installation trouble
    well guys as most of you know, vt have the stupidest headlights int the world lol. im having trouble changing my parkers, the only option i can think of is taking apart the headlight to put the new parker globes in :S or taking a hammer to my headlights.
    i assume there has to be an easy way im just not seeing?? can anyone please give me an EASY way to change my parkers! i know its probably a stupid question but im really having trouble with this and would prefer to not have to pull apart my headlights!!!! thanks guys
    VT Commy
    Mar 2010
    Adelaide!
    I need to do the same thing atm mate, I did see a how to for a VX Berlina but don't know if it's the same as i haven't had a look yet. It says in the bay behind the light there should be a couple of wires going into the headlight and if you give it a good tug (hehehehe) then it should come out with the globe attatched and then it's as simple as changing them over....well that was the gist of it. I haven't had a look yet so I'll update when i get the chance.
    EDIT: K, I had a look and there's a cap behind the light (in the bay) that twists off and once removed it looks like there's a wire there, this MAY be attatched to the parker I however wasn't game enough to yank it as I didn't want to break anything lol. Also the cap takes a little while to get back on, as you can't see what you're doing lol.
    Quote Originally Posted by mattgreen View Post
    sorry dude but my 3l manual magna blew any commodore out of the water. even stock ls1's i wouldnt be talking shit about cars you have no idea about
    Vt Clubsport
    May 2009
    cheers mate okay im giving it a yank in 5 mins (nothing suss) lol. ill let you know how it goes, also, ive been told u can get them out with pointy nosed pliers??? maybe thats worth a look if this wire trick doesnt work.
    Verynice's Avatar
    Verynice is offline Band
    VS Caprice 5L
    Aug 2008
    SA - The Backwards State
    Yes, it should be a dust cap, unscrew it off, which will let you get to the parkers and main headlight. The parker is obviously the small one with 2 wires in the back of it.
    VT Commy
    Mar 2010
    Adelaide!
    Quote Originally Posted by Adriianz View Post
    How'd you go?
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Unscrew the dust cap then unplug the connector to the main hi/ low beam , that way you can access the parker . If your really keen you can remove the hi/low beam globe to make it even easier but make sure you don't touch the globe with your fingers as it will shorten its life
    vt commodore
    Oct 2010
    kooweerup
    Cool
    you dont need to take the headlight out at all just get a pair of pliers onto the back of were the parker goes into the actual housing of the light and give it a little turn and pull it back and theres ya parker i did mine not to long ago for a roady
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Take off the dustcap, then take out the headlight globe, then just push the old globe out from inside the headlight. Much easier than trying to reef on the 3mm of plastic they give you
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
  1. vt Parker globe installation trouble
    By Adriianz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-10-2010, 12:47 PM
  2. Parker Out
    By Mark Nightingale in forum VY Holden Commodore (2002 - 2004)
    Last Post: 12-09-2010, 06:49 PM
  3. parker lights
    By bpottz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-10-2008, 09:10 PM
  4. parker +ve
    By spd_dmn in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-10-2008, 06:42 PM
  5. Power Button Globe & A/C Globe Replacement
    By mourati in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-08-2008, 11:39 PM
