Results 1 to 15 of 15
Thread: VT back end, VY front end
    '99' Vt wagon series 1, 3.8lt auto
    Oct 2010
    whitsundays
    Question VT back end, VY front end
    Hey guys, just trying to get some info on whats involved with fitting a VY front end (bonnet, front quarter panels, front bar, headlights) to my VT wagon. Will i need to change the front bar supports, can it even be done. Any info would be appreciated. Thanx
    vg ute
    Jun 2010
    shepparton
    it can be done seen, www.streetwagons.com guy named kane has put a vy gen cluby sport sport front on his, far as i know it will joint up need the clips and maybe a vy reo bar
    vt ss s2 6spd
    Sep 2008
    info i was given on another forum
    You will need:
    VY/VZ bumper (prices vary)
    VY/VZ guards (prices vary) and guard liners ($40 each from Holden)
    VY/VZ side indicators (prices vary) with new short wiring harness if using VZ guards ($60 each from Holden)
    VY/VZ bonnet ($500-$600 from Holden, $150 - $300 second hand)
    VY/VZ cowl panel parts (3) (cowl panel part 1, $30, cowl panel part 2 (clips over part 1): $18, cowl panel part 3 seal: $10)
    VY/VZ Headlights to suit your bumper (prices vary)
    VY/VZ front bumper reo bar ($100 from Holden)
    VY/VZ front bumper on VT/VX
    Firstly, the VT/VX reo bar (the big bar you see when you take off the bumper) is different (slightly thicker and much heavier) to the VY/VZ reo bar. To install a VY/VZ bumper on a VT/VX you need to use the VY/VZ reo bar. The VY/VZ reo bar is also mounted slightly differently onto the chasis. The mount holes are exactly 20mm lower than the VT/VX mount holes. You can see for yourself if you look on a VY/VZ car (with the bumper and reo off), you'll even see the higher VT/VX mounts holes on the chasis rail as Holden never bothered to revise the chasis rails.
    So you will need to re-drill the mounts 20mm lower to fit the new VY/VZ reo bar on. Get yourself a good drill as it is very tough to do. Bolt the new reo on and then your VY/VZ bumper will fit.
    VY/VZ bonnet vs VT/VX bonnet
    You will need: VY/VZ bonnet, VY/VZ washer jets (two, $10.50 each), VY/VZ cowl panel (two pieces, costs about $40 total), VY/VZ cowl panel seal ($10) and VY/VZ bonnet hinges ($18 each).
    Just a note, do not use a VY bumper with a VZ bonnet (and vice versa), it won't fit properly. You can also keep your old VT/VX bonnet if you use a VY bumper (as seen in my pictures), there will be a small gap on either side of the VT/VX cowl panel (where the wipers sit) though.
    Bonnet is an easy process. Remove VT/VX bonnet with its hinges and rip off the old cowl panel. Install the new bonnet USING the VY/VZ hinges. VT/VX hinges are different and won't fit properly.
    Cowl panel is a little tricky to figure how on how to install but think of it like a puzzle. If I could figure it out, anyone can. It all clips together basically anyway.
    VY/VZ no longer has washer jets mounted on the bonnet like the VT/VX models. They are now mounted in the cowl panel (they click in). You can even use your existing VT/VX washer hose and cut it to size. You will even have some left over.
    VY/VZ Guards
    Just a quick note, you can use VY guards on a VZ bumper and vice versa (I have VZ guards with my VY Senator front). VY/VZ guards will fit on VT/VX models with small modification. You need to use a hammer and curve each side of your VT/VZ guard reo (shell) very slightly. To see what bit needs curving, stand over your car and try to put on the new guard while looking down inside and you will see the offending piece of metal.
    Two things that will annoy you:
    1. You will need to buy new VY/VZ guard liners from Holden ($40 each) as the old VT/VX liners will not fit the new bumper. You can leave them off but you'll get a lot of dirt stuck in your wheel wells and door hinges.
    2. VZ models use a different side indicator harness. So if you buy VZ guards (fluted or not), your existing side indicator harness will not fit the new VZ indicators. You'll have to cut them off a wreck. New from Holden they are about $60 a side (short harness), I think not. I got them for $20 for a pair from a wreck. For shits and giggles, the same VT/VX part is only $8 a side. Bloody Holden.
    VY/VZ Headlights
    Just learnt that VZ projector headlights, although they look they same as VY projector headlights, they won't fit a VY bumper and vice versa...
    Make sure the VY/VZ headlights you buy are the correct ones to fit the model your VY/VZ bumper is from. They bolt and plug straight in perfectly however, if you go for projector headlights (VY/VZ HSV, VY/VZ Calais, VZ SS etc), you will need to modify your dip switch wiring (inside the steering wheel column surround, indicator/high beam stalk). I can provide a diagram from LS1 forums if needed. If you don't modify your dip switch wiring (I haven't yet), then when you select high beams, your low beams will turn off.
    VY/VZ side skirts will fit your VT/VX without any problems.
    MR_VX's Avatar
    MR_VX is offline Forced to be Fast
    VX S pac SII Raptorcharged
    Mar 2009
    Townsville, Qld
    why would you that would be ugly as f*ck. round at the back and square front yuck
    Check out my ride here >>>>My VX Raptor
    say NO to chev badges
    Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
    For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
    Oct 2010
    whitsundays
    Thanx GR3GA, all that info is awesome, great help man now to start the search for parts.
    And MR_VX, take another look man, rear ends are exactly the same just different rear bar which will be changed.
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    Quote Originally Posted by jaypog View Post
    VT back end, VY front end-vy-rear.jpg VT back end, VY front end-vx-rear-end.jpg
    you might wanna check the distance between the bar and tail lights
    VY executive
    Oct 2008
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    hahaha well i totally missed that one lol my bad
    VY executive
    Oct 2008
    Lol, I understand your point though, vt/vx rear end and vy/vz front end dont blend. But on wagons it works.
    2003 VYII S 3.8L M5
    Jul 2010
    NSW
    I've seen a vx sedan with a vy front end on eBay a month or two ago and it looked ridiculous... You can def get away with it on wagon's however
    Oct 2010
    whitsundays
    All is forgiven lol,
    And on a sedan. . . . . . . Y the hell anyone would consider doing that is beyond me, good way to wreck a good car!!
    Also, Anyone looking to sell half of there vy let me no lol !!
    vt ss s2 6spd
    Sep 2008
    JMP
    JMP is offline
    VT Calais
    Jun 2010
    in the end wouldn't it work out cheaper just to upgrade to a vy instead? plus the car would be worth more also.
    Vt s pack
    Aug 2011
    Lockleys
    Hey I was wandering if a ve front bumper with vz front lights would look good as I'm in process of doing it ??
  15. #15
    GEN3RATD's Avatar
    GEN3RATD is offline living the low life
    VXII SS
    Nov 2010
    Crib Point, VIC
    wagons and utes it looks good, looks like horse shit on sedans.
    If it isnt tuckin, it must be suckin
  1. Back of front seat
    By nickmarlow1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-01-2008, 08:43 AM
  2. vx front and back seats in a vn
    By Cossack1977 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-02-2006, 09:23 PM
  3. Which Way: Front Or Back
    By menzy in forum Car Audio
    Last Post: 25-03-2004, 01:24 PM
