Results 1 to 4 of 4
Thread: HELP Engine Light / Transmission light and rough gear changes
    VT Commadore
    Oct 2010
    Lockyer Valley
    Smile HELP Engine Light / Transmission light and rough gear changes
    Hi. I have a 1999 VT commodore and a few days ago the engine light/ transmission light came on (I think that's what it is I didn't get an owners manual with it it looks like a little engine with a lightning bolt in the middle). and when the light is on the transmission gear changes are really rough. It was due for a service so i took it in to the mechanic and he did a full service and put it on the computer and there were no faults recorded. The light doesn't come on till you have been driving for around 10 mins so the mechanic never experienced the problem first hand. Am really worried that there might be something really wrong with my transmission and the clunk sound that happens with gear changes is really discerning. Does anyone have any idea what may be causing it???
    Thanks
    sxc_sound's Avatar
    sxc_sound is offline getting Kustom
    VT Series 2 S pak
    May 2008
    Parkdale
    Just check the oil levels to start with. From there...maybe get it looked at by a transmission place
    00' WH Stato LS1 A4
    Dec 2008
    Adelaide, SA
    Did he check your transmission fluid too? I would be taking it to a trans/diff shop to get serviced and looked at.
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Possibly a shift solenoid or TPS problem. When the problem occurs, slow down and manually shift into first gear. Accelerate to around 10kph or so and then slow down a couple of times. If the transmission automatically changes into second during this process it's probably a TPS problem.
  1. rough idle, runs rich, engine light, driveline shudder
    By penleja in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-01-2012, 12:25 PM
  2. ENGINE light, ABS light, TRAC OFF light AIRBAG light and OIL light
    By jamierawr88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-10-2011, 09:06 PM
  3. transmission and engine light
    By nathsvrbt1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-01-2006, 03:14 PM
