Results 1 to 11 of 11
Thread: Car randomly drops/loses power/stalls?
    MkyHnly's Avatar
    MkyHnly is offline Finally enjoying my P's!
    VT S Pack - VC SL/E 253
    Jun 2009
    Croydon, VIC
    Default Car randomly drops/loses power/stalls?
    I have been driving my car around today and have just recently noticed a problem with it (only started occurring today)
    It started when i put my foot down a bit to overtake, the car lost power for a good second before kicking down a gear.... was quite weird
    Then tonight i went to go for a drive, the car lost power when pulling out of a street, then completely stalled in the middle of the road (lost power steering, everything) and then would refuse to start (machine gunning) for about 30 seconds.
    I took it back to my estate and then drove around the small courts and it does it normally when turning corners, especially the bowls of the courts. It either loses power for a second then kicks back, or just stalls completely and struggles to start...
    Any ideas? Its for my VT S1 S pack btw... auto v6. Could it be transmission problem or more engine problem?
    S.T.K.E's Avatar
    S.T.K.E is offline Wiggle Wiggle Wiggle
    Holden Jackaroo 3.0TD
    Mar 2009
    Brisbane Northside
    Does it Sputter like it's not getting any fuel. when you turn the key to the on position can you hear the fuel pump prime.
    STKE's Ride: http://forums.justcommodores.com.au/...lais-3-8s.html
    Quote Originally Posted by Tim Smtih
    Also you could just whisper in his ear "guess what i did to your mum last night?" And walk away laughing.
    nstone63's Avatar
    nstone63 is offline wants a new car
    1988 VN Executive
    Mar 2010
    Roxby Downs SA
    I had the exact symptoms driving my partners ef falcon. The problem with hers was an electrical connector had come slightly loose on the LPG system, causing a solenoid to open/close randomly as it shook around...
    not sure if it's the same thing or if yours is even on LPG but worth a shot
    VT Acclaim Wagon
    Oct 2008
    I have a similar problem, I am hoping someone on here has a solution. Mine does not stall but does hesitate when I put the foot down. getting new plug leads and fuel filter next week. Already has new plugs and coilpack
    MikeCuzzy's Avatar
    MikeCuzzy is offline How hard can it be?
    2007 VE Omega 3.6L & 1998 VT Executive 3.8L
    Jan 2010
    Wollondilly, NSW
    Did any warning lights come on?
    The New Ride - The Class 2 Shuttle Craft (VE)
    I'll be he comes to get you, some shopping trolley kind of thing, that gets you where your going nice and slow... Well off you go that's fine, the pleasure's all mine.
    When I light the nitro on my HQ 454 Monroe!
    MkyHnly's Avatar
    Jun 2009
    Croydon, VIC
    gday guys, i have spoken to people including my mechanic and they say fuel pump, or not enough fuel pressure in the line... weird thing is though that it only happens when i turn right, and the car doesnt hesitate to start if it has been parked in the driveway for a little while
    my partner put a full tank of petrol in it and it doesnt go to stall anymore, but she says it still has a lack of power and runs really rough
    would you recommend just a service, or a check, or should i pay the $250 to replace the fuel pump, which was only replaced 12 months ago?
    cheers
    99 VT Commodore
    Mar 2010
    south east queensland
    lad, i have had the EXACT SAME PROBLEM and am still havin it!! you'll see my topic i just posted about it. i replaced my fuel pump by myself it was easy - my car was doin the same stalling when turning right - im assuming its an incorrectly fitted fuel pump assembly im waitin for a reply to confrim this though but i'd say thats what it is man..
    - stalls on low fuel when turning right (fuel sloshing away from the pick up on the assembly)
    MkyHnly's Avatar
    Jun 2009
    Croydon, VIC
    let me know how you go mate with replacing it... my mates and i have done it on a couple of vs's and if it fixes your problem i should just get it done myself.
    it doesnt do it on a full tank which explains the stalling
    cheers
    VT
    Nov 2010
    Default Hi - just wondering if you srted your problem - as i have the same issue!
    Hi - just wondering if you srted your problem - as i have the same issue! ( stalls on low fuel when turning right (fuel sloshing away from the pick up on the assembly))
    Quote Originally Posted by CV6Z View Post
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    +1 fuel issue
    a swirl pot is in the fuel tank and when you corner it holds fuel close to the pump so that it doesnt suck air
    i would in the above case connect a fuel gauge and then drive it until it died
    when it died if the pressure of fuel was low only on corners then i would check/replace pump and check if swirl pot was in place correctly
    if pump was at fault normally there would be an intermittant no starting fault as well... or long cranks
    if pressure was good when fault occured i would be checking for codes and for loose or shorting wires on ignition module air flow meter and crank sensor
    GSXR1000
    Apr 2010
    WA
    hmmm might have to look into this myself.
    Mine feels sluggish most of the time, my gf's 2000 model pulsar feels like it has more poke at times! haha
    might try the fuel pump as I get the long cranks before it kicks over too, particularly when warm for some reason.
  1. VS V6 drops power sometimes!!!
    By skootaroo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-06-2010, 07:41 PM
  2. Vs v6 randomly stalls
    By Dave818 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-06-2010, 06:47 PM
  3. VS engine slows down and loses power at 3500-4500rpm
    By Fonzie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-07-2009, 08:52 PM
  4. VN drops back a gear when speedo drops out
    By V8commodore_chick in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-11-2006, 12:18 AM
  5. V8 Power Drops
    By neo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-08-2006, 10:53 PM
