Results 1 to 4 of 4
Thread: now I need help, door not staying shut
    VT Acclaim Wagon
    Oct 2008
    Default now I need help, door not staying shut
    My VT passenger rear door will not stay closed. Will not even catch. Try to close it and it bounces open again. I may have to change the lock mechanism as it seems that it is broken. I know how to get the trim card off but how do I get the locking mechanism out?
    2009 VE SS SPORTWAGON
    Sep 2010
    Default Removing door lock
    Their are 3 torque bit screws around the lock mechanism undo them also 2 rods one for the inner door handle and one for the lock button undo the clips holding these and the rods will pull out (you may be able to leave these on and pull the mechanism out can't remember off the top of my head) then unplug the wiring pulg at the base of the lock and the lock should come out.
    Be sure when replacing that the outer door handle rod slips back into its seat on the mechanism the handle has a white plastic sharft that goes into the green seat on the mechanism. Otherwise the handle wont work..
    Reverse the top instructions and besure to test the lock befor shutting the door by clicking the lock mechanism shut with a screw drive and the using the outer door handle to see that it pops open again
    then wind you window down and shut the door and try your locks and inside door handle.
    Also remember to try your key lock button to see that the central locking is working befor you put the trim back on. It's easy to forget to plug the wiring back in
    note: If inside door handle is not working you may have the child lock switch on.
    Hope this is helpful
    VT Acclaim Wagon
    Oct 2008
    AZZ.22Y, thanks for that. Will be in to it as soon as I get a replacement locking mechanism.
    99 VT Sedan
    Feb 2010
    Quote Originally Posted by graham7773 View Post
    not sure without looking at it but
    On my wagon sometimes the lock ...locks it self when its open...Just press the button and put a screw driver on it to unlock it
    Sorry just read again its the passengers door
  1. Need to remove door trim with door shut.
    By Kirbs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-01-2010, 03:30 PM
  2. door ajar light staying on
    By simon.w in forum VE Holden Commodore (2006 - ?)
    Last Post: 31-03-2008, 08:44 PM
  3. Front Door - not staying open
    By SSV8pilot in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-06-2006, 03:12 PM
  4. door on console wont stay shut
    By ls2 wannabe in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-03-2006, 09:00 AM
  5. Door wont shut/close
    By VS1Tonner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-09-2005, 02:46 PM
