Results 1 to 25 of 25
Thread: Coolant low in radiator but high in reservoir
    VX Berlina S1
    Sep 2010
    Caboolture
    Default Coolant low in radiator but high in reservoir
    Hi,
    bought a 2000 VX Berlina a few weeks back and have had to top up the radiator. Checking the radiator the level is much higher then the 2nd arrow but the level in radiator is consistently low (can barely see it). Any ideas?
    No obvious leaks that I can see so far. Oil ok and exhaust doesnt smell sweet.
    Cams
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    VX Berlina S1
    Sep 2010
    Caboolture
    VT Acclaim Wagon
    Oct 2008
    Best case, radiator cap? Or time for a pressure test looking for leaks. Sounds like your water is not recycling back through the cap, I hope so as the news only gets worse if it is anything else like hoses, inlet manifold gasket, blown head gasket, cracked head, cracked block but these become obvious when you find caffe latte on your dipstick instead of oil.
    VX Berlina S1
    Sep 2010
    Caboolture
    oil seems all good so far. Dipstick fine, under cap fine as well.. any ideas what a pressure test is worth?
    99 VT Sedan
    Feb 2010
    Quote Originally Posted by cams75 View Post
    I am having exzact same problem
    Water low in radiator but overflow is at full mark
    I have changed radiator cap the hose that goes into overflow
    I have had presure test found tiny leak in a couple hose's put new hose's on but still same thing happening
    Does anyone know the answer to this problem?????????????????
    VX 'S' S1
    Apr 2005
    South East,Victoria
    I had same problem too , Replaced the overflow hose as it was blocked . Had trouble getting it out of the bottle as it had swollen to twice is size and was blocked with crap
    99 VT Sedan
    Feb 2010
    Quote Originally Posted by Dayvo View Post
    Did it fix the porblem??
    VX Executive S2
    May 2006
    Frankston South Vic
    99 VT Sedan
    Feb 2010
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    make sure the overflow hose goes into the water in the overflow tank or it will suck air back into the radiator instead of water
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Yep , seems to be ok now . If your gonna change yours , pull the rubber grommet out after removing the hose , then feed the hose through the grommet using dish washing liquid to make it easier then push the grommet back into the bottle .Also pays to remove the bottle and give it a good cleanout
    Dec 2009
    I just had this problem, the radiator level when cold was just visable in the bottom of the bit the cap goes onto. I filled it a couple of times, re-bled it and the level dropped back to the same point and the level in the overflow was going up. I bought a new radiator cap and the problem is fixed. I noticed on a friends VT that the overflow hose was pretty swollen up in the resevoir, mine is still fine.
    How clean is your cooling system and how long since it has been flushed? I am asking incase there is crud blocking up the tube or cap as my mates is pretty crudded up as he doesn't service it properly.
    What you need to do is check the overflow when the motor is hot and cold and see if the level is changing, ie it goes up when hot and back down when cold. If it's going up then down then there is probably a leak somewhere, if the level goes up when hot and does not go back down then there is something wrong with the cap or overflow hose to the bottle.
    Don't take the cap off when the motor is hot as the coolant is expanded and will if hot enough boil once the pressure is removed as increasing pressure increases the boiling point.
    99 VT Sedan
    Feb 2010
    Quote Originally Posted by wortus View Post
    Thanks for the advise
    Well i've have the car for 18 months its been flushed around 7 times trying to fix this problem
    Last time i done it was 1 month ago
    I have new radiator overflow pipe....new radiator cap...new termosat...been presure tested..its holding presure now...but still same problem.....so i'm thinking there is a slight tiny tiny leak only when hot in the plastic..Thats why the presure test doesn't pickit up....
    So ???????
  15. #15
    vt s1 dunnydoor
    May 2010
    should of done pressure test first if nothing shows on test then it is a leak in the engine some engine leaks may not show straight away
    ive seen coolent leaking down the outside of the engine nothing inside
  16. #16
    VX Berlina S1
    Sep 2010
    Caboolture
    well new radiator cap and level in the radiator is at the top also some sludgy crap out of reservoir half hanging out of hose.. on the other hand followed the misses this morning and seemed to be excess steam (yeah it was raining and Im paranoid) but cleared up after 2k's then car cooled down for 90 mins in the torrential rain and same again.. Am thinking either im paranoid (no temp issues at all) or maybe inlet manifold gasket.. if the gasket anyone had one done recently by a mechanic and what it cost them?
  17. #17
    VX 'S' S1
    Apr 2005
    South East,Victoria
    I done my intake manifold gasket the other week took me about seven hours , 4 of those were removing the old gasket and cement It must have had a bodge job before i bought it and they have used a whole large tube of gasket cement all over the gaskets, manifolds and heads . Cost me about $120 in parts . Give it a compression test to see if it is the head gasket .
  18. #18
    VX-II wagon V6
    Oct 2010
    sydney
    Default Re. Low coolant level
    I couldnt stop this in mine till i changed the inlet manifold gaskets, i had oil in the water by this stage approx 220,000km. Changing the gaskets solved the problem, the cooling system must depressurise through the leaking gasket, therfore no vacuum in the system to suck the water out of the reservoir when it cools down. I was getting sick of topping up the radiator only to have the shit end up in the overflow bottle. '
    Hope this helps, Dave.
  19. #19
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    I also have the same problem, coolant not returning back to engine from over flow tank when it cools down. ALSO, I keep getting engine oil traces in over flow tank.(coming from radiator overflow) I have flushed out complete system and changed radiator cap, but the problem persists. It's been doing this for several years. I have been thinking head gasket is leeking the oil from the rocker feed into the coolant, but reading dfb50's post boosts my hope that it is only the valley cover gasket.
    Pablo
  20. #20
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Quote Originally Posted by dfb50 View Post
    lol 220,000km this must be the magic number , Thats about how many Kays mine has done and i had to change the gasket
  21. #21
    VT Berlina
    Oct 2010
  22. #22
    May 2006
    Mine never alters on the temp gauge! ...Though, I don't let it drop too low.
  23. #23
    VX Berlina S1
    Sep 2010
    Caboolture
    temp hasnt changed a bit. even was monitoring it on digital the other day and was sitting at 83c ... guess its off for a pressure test for piece of mind.
  24. #24
    Vy S V8,VT V6, Rodeo 3.5 V6 4wd
    Aug 2008
    Default use a stop leak product to check if the leak is internal
    Hello,
    I sometimes use a product called SEALTAB from my parts man, it is a powder that goes into the radiator and seals any small leaks that may be there, have used in on a 4 cyl motor with a leaking radiator and it fixed it within a week. Temporary I know but it helps buy some time and confirm the source of the leak.
    Worth a try.
    Jonesy VT
  25. #25
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    I did my ecotec intake gasket and my brothers super 6 at around 150,000k's. Its when radiator, water pump all start going.
    Key to water radiator level is the overflow must only be 1/2 full. When too full it makes a vacuum and pulls water from the system. I reckon the older overflow system was better with the see through bottle. New system you cannot tell.
  1. Brown sludge in coolant reservoir + coolant level dropping
    By phuecn in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-11-2010, 08:03 PM
  2. where should the coolant reservoir to radiator cap hose sit?
    By joeyd in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-03-2010, 11:39 PM
  3. VX L67 - Oil in Coolant & reservoir
    By Raging Bull in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-04-2009, 03:16 PM
  4. [VIC] WANTED - VR VS Radiator Overflow Reservoir Bottle must be brand new genuine (NOS).
    By The Harvester in forum Swap / Wanted to Buy / Trade
    Last Post: 06-03-2009, 04:14 AM
  5. radiator.. coolant... etc...
    By TWOJZ in forum VL Holden Commodore (1986 - 1988)
    Last Post: 28-04-2008, 07:39 PM
