Results 1 to 2 of 2
Thread: which way does the fuel pump assembly face when putting it in the tank? URGENT!!
    99 VT Commodore
    Mar 2010
    south east queensland
    Exclamation which way does the fuel pump assembly face when putting it in the tank? URGENT!!
    ive got my tank out of my VT commodore its a V6, have been having trouble with it stalling when i turn right n with low fuel - fuel obviously sloshes to the left of the tank and away from the pick up and it stalls from what i assume is incorrectly fitted assembly (fuel pick up wasnt sitting at the bottom of the tank ect) i made the mistake of not taking note of which way it faces when putting it back in so i need some help please =)
    on the top of the assembly is the 3 hose connections - 2 of them are marked "F" and "R" im assuming that means FRONT and REAR as in which way they face?? "R" to the rear and "F" to the front? but also that means the hose lines are facing towards the fuel filer side and away from the hose's??? im confused n just need to know which way they face so i dont have to go through this again...
    cheers
    VX Commodore S Supercharged
    Sep 2010
    Would this help...?
    Attached Files Attached Files
    2001 Commodore VX-S (Series I)
    12.04.2001 - 29.04.2010
    2002 Commodore VX-S Supercharged (Series II)
    23.05.2010 - Current
  1. Fuel Tank,Fuel Pump Assembly and Swirl Pot.
    By Brett_jjj in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-02-2011, 10:12 PM
  2. does the fuel pump assembly sit in the tank a certain way? got stalling issues...
    By CV6Z in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-08-2010, 11:49 PM
  3. have had to wack the fuel tank to start my car!! is my fuel pump stuffed?
    Last Post: 01-08-2010, 04:13 PM
  4. How do you remove the fuel sender/pump assembly in a VR V8 sedan?
    By savage1987 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-05-2008, 01:19 AM
  5. Help!!! Putting fuel tank back in with new breather hoses..
    By Kartbro in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-01-2007, 11:25 AM
