Ok guys, having some major problems with my vt. When i try and accelerate the engine stalls, at idle its fine though.
Ive changed the petrol filter, changed the air flow meter and also added some injector cleaner and none of these solved the problem.
does anyone have any ideas on what the issue could be?
bumpppp...........
my guess is it might be your fuel pump or your ecu
fuel pump is working fine. ecu well dont know how to check that?
this problem is driving me nuts, id be sure someone on here would know of it, but seems not![]()
i had a problem like that with my vs to find it was the DFI module ( the thing your coils are sitting on ) as under load it lacked spark and stalled ... i took it to an auto electrician to test for $33,, ( shop round to find a cheep one as some charge $40-80 in my case )... as they have the same motor they also may be a problem...
also some auto electrician have a scan tool to scan your ECU as there may be a error code im shore if its ur ECU ( its only a guess )
hope this may help
thanks guys. will try and sort this out soon
