I went to plug my gps charger into the cigarette and wouldnt give a charge so im assuming the fuse is blown, and i was wondering where abouts it is and what amp it is?
should be behind the panle under the steering wheel. i think its a red 10A fuse
Check out my ride here >>>>My VX Raptor
say NO to chev badges
Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
Remove the fuse panel under the steering wheel, on the back of said is the locations and amps of each fuse. It's all rather self explanatory, if you get stuck let us know. One possibility is that the cigarette lighter socket has come loose behind the dash, check the fuse first, but if it checks out. That could very well be the problem.
Mike.
The New Ride - The Class 2 Shuttle Craft (VE)
I'll be he comes to get you, some shopping trolley kind of thing, that gets you where your going nice and slow... Well off you go that's fine, the pleasure's all mine.
When I light the nitro on my HQ 454 Monroe!
Okay will look at it tomorrow cheers! much appreciated
Where abouts is the panel I had a quick look but couldn't see anything, I probably looked right at it
If you can wait till this afternoon I'll take some pictures once I get home.
Yer okay I'll wait to see the pictures thanks![]()
Stick your hand below the steering column and pull on the plastic. downwards. from either side (one at a time). it will un clip and pull down to reveal your fuses. and there should be a diagram printed below the fusebox to say what is where. Just look for cig.socket or similar
Yep! Found it! Thanks guys
