hey all!
im looking at getting a supercharged engine and getting rid of my stock! and then i can do mods to this one? do they go hard or what?
171kw..... just about the same if not more than a stock v8
i have pulled up beside heaps but they dont give it any? i want to know if they make much noice as im a p-plater
A completely stock engine only makes a bit of whine and the exhaust note is a little different. But there is really not much difference in noise, but there is a huge difference in torque, the ecotec puts out around 305 Nm at 3600 whereas the S/C engine puts out 375 Nm at 3000. And all you need to do to have it go off its tits is buy a 10psi pulley for like $240, doesn't need a tune but you'll have to run 98 fuel.
None of us are as cruel as All of us. - Anonymous
only the noise from the supercharger, not a v8 sound. but for a couple hundred you can get an exhaust kit, but you can do that on your stock v6 if your looking for sound.
i have pacemaker heads and exhaust system, what else would i have to change? like the engine im getting comes with loom and ecu, do i need the auto aswell? yeah bro id upgrade it aswell! im worried the cops might hear it
the cops will hear what? im pretty sure a supercharger is fine on your p's, but any performance enhancing mods are illegal in victoria.
Well you're gonna have to be more careful around cops for sure, and once they open the bonnet you're f*#$%d.
As for what you'll have go go through to get it set up I really don't know, but if you've got all the electrics I couldn't imagine
it would be too strenuous.
lol ill get it, how much torque would a 10psi pulley do? if i upgrade it
Well my cars got the RedBack Catback Ehaust 2.5 " and it's fricking loud when i give it some juice.
Was going to my friends house giving it a bit 2 streets away from hers, she happened to be out the front and said "thats was freaking loud" when i turned up.
The only other thing done to the engine is a Growler cold air intake system.
You get an extra 15 kw or so from the pulley upgrade so I don't see why the torque wouldn't go up by 30 or 40 Nm
because thats what the positive displacement superchargers are for.
mine has twin 2.5 exh, extractors, 2.9" pulley, w2a cooler, stage 2 shift kit, corvette servo, 69mm tb, 4" intake and pod, 3.46 lsd and mafless kalmaker tune i think thats it lol and yeah its loud but goes pretty hard man. I have beating a few ls1's and a few 5ltrs and a xr6t. Hopefully that helps with your decision.
