Results 1 to 7 of 7
Thread: water in boot lid and loose boot lid
    VT Berlina
    Mar 2006
    Default water in boot lid and loose boot lid
    Just wondering if anyone has experienced something similar.
    Water is getting into the boot lid whenever it rains. It appears to be getting into the lighting assembly that runs along the back of the boot lid.
    Whenever I open the boot all the water runs out from the light assembly and into the actual boot, therefore making the boot almost useless, as everything inside gets wet.
    I've also noticed that when the boot is closed I can grab the boot and rock it up down slightly. Previously it would lock tight and you couldn't move it at all when it was shut. It appears that something as loosened over time. I'm not sure if this has anything to do with the water issue
    Any suggestions on whether this is easily fixable?? The water issue sounds like a seal that has deteriorated over time, but I'm not sure if it's a DIY thing or not.
    vt s pack
    Oct 2010
    brisbane
    just drill some holes in the boot under where the water comes out, that way when u open you only get a tad run out, just make sure u out some paint over for rust
    VE S2 SV6
    Nov 2009
    Open your boot. On the inside of the boot lid, where the steel is you should find around 4cm from each corner a sort of half round bumps. It's about 8mm long and sits out about 3mm. Get a very small screw driver or scriber and push through the paint. Behind the paint will be fill of putty. Scrape the putty out and your drain holes will work. For some reason holden painted over the drain holes in the VT.
    Sorry I don't know how to post photos, but you should be able to find the drain holes.
    VT Berlina
    Mar 2006
    VP Commodore Executive V6
    May 2009
    Brilliant advice! It just fixed the same problem in my son's 50th anniversary edition Vt, we may check the wing seal as well later but this fix allowed a good 1/2 cup of water to drain out as soon as we did it. I imagine this would have caused some rusting eventually
    97VT SS super6,daily 05 holden barina(opel)!!
    May 2009
    lolol yeh came across this not so long ago meself had the same prob here's a pic just in case m8 : ) easy fix!!
    before:
    after:
    Also check my ride,sitting on HSV R8 19's
    " And on the Seventh day ,GOD created Commodores!!!! "
    VE S2 SV6
    Nov 2009
    Excellent photos.
    Solves any confusion
  1. Water in Boot
    By Rodeo058 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-05-2009, 09:11 PM
  2. Water in boot Lid
    By G4orce in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-12-2008, 07:40 PM
  3. water in boot
    By dale s in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-06-2006, 01:21 AM
  4. Water in VS boot lid.
    By SunCoastSister in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-04-2006, 02:06 PM
  5. VS - Water in boot lid.
    By pod in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-07-2004, 09:48 AM
