Results 1 to 14 of 14
Thread: supercharged 6 missing under full throttle?
    slepar's Avatar
    slepar is offline omg duz it like...dose??
    vn ss
    Mar 2007
    Default supercharged 6 missing under full throttle?
    hey guys i have a wh statesman supercharged 6 and its missing slighly under full throttle? doesnt miss at all on idle only full throttle, any ideas?
    all help much appreciated
    cheers
    doin skids for the kids and doughnuts for the grown ups
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    coils, leads ,plugs ,or plug gap too big ,cas on its way out or leaning out for some reason will all make it miss
    slepar's Avatar
    vn ss
    Mar 2007
    thanks for that mate, the leads look fairly new, cas? and that is lol
    в∞ѕтεכ √&
    Jul 2008
    NZ
    crank angle sensor in behind the balancer on the front of the engine
    2002 VX Calais
    Apr 2005
    Gold Coast
    i would start with the leads mine did the same thing and the terminals on the leads had corroded out and they basically were just sitting on the coil pack not clipped on tightly
    VX S S/C & BA XR6T
    Feb 2009
    vx custom 600RR
    Oct 2010
    slepar's Avatar
    vn ss
    Mar 2007
    done a fault code check and yea only got 12
    VT spac super6
    Nov 2008
    Riverton sa
    Pull all the leads off and push them back on.. my super6 has one lead that comes loose every 10 thousand ks try that see how you go
    2000 VT S-Pack II
    Dec 2009
    SE Queensland
    had same issue with my car (not a super though), got a service withg a new belt and plugs/leads and it is now gone (y)
    slepar's Avatar
    vn ss
    Mar 2007
    i will be giving it a full service very soon. i only just brought it and i filled it up with vortex fuel and it seems to have stopped? is it possible bad fuel would cause it to miss?
    в∞ѕтεכ √&
    Jul 2008
    NZ
    if it had 91 in it that can make it ping and the ecu pulls timing can feel like a miss when it happens
    VT
    Apr 2005
    QLD
    I would put money on fuel being the issue.
    I had a drama recently where even on the 91 RON timing map, it would ping its head off.
    Run better fuel through it and a bit of booster, fixed. Back onto the 95 RON map
    So yeah, fuel.
    VY SII HBD Calais L67
    Dec 2006
    Is the car modified at all? Smaller charger pulley or anything?
    Will most likely be leads but if you have a smaller charger pulley and haven't changed to a different gap plug it could be a possibility too. Most common cause of break down is spark related
    VYII Calais L67
  1. vt 3.8L Supercharged missing hose
    By cr69zy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-09-2010, 06:37 PM
  2. HELP!! Code # P0012? knocking or missing at 1,500 rpm or when just on the throttle?
    By smokin_vx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-06-2009, 09:00 PM
  3. how to get full throttle with shift kit
    By baza in forum V6 Development And Modification
    Last Post: 07-03-2008, 07:26 AM
  4. 1/3 throttle is faster than full
    By VSIIBerlinaL67 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-11-2006, 09:12 AM
  5. 0-100 full throttle after dynotune
    By CustomVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-09-2005, 12:24 AM
