Results 1 to 11 of 11
Thread: Serious problem with VT
    VT
    Oct 2010
    Default Serious problem with VT
    Hi there.
    I have a '99 VT and in the past month or so it has had overheating problems. It seems to be losing water somewhere and I put about 2 litres in everyday (not enough). And recently it has gotten very bad. When I would drive 15 minutes to work there would be steam coming off one of the hoses.
    On thursday I drove to work and towards the end of the trip it started making a funny noise when I put my foot down on the accelerator but only when I initially tap my foot on the accelerator, if I continue to hold my foot on the accelerator the noise seems to go away. It sort of sounds like a rattling noise.
    So I continued driving and just as I pulled into a parking spot the engine shut off. I open my bonnet and there is white smoke/steam pretty much everywhere and the car wouldn't turn back on. So I went to work and came back to it later (10 or so hours later) and it started again, put some water in it and got home fine.
    But then yesterday it did exactly the same thing (engine shut off, white steam etc.) Also I might mention the 'hot' light on the dashboard never flashed and the needle was about halfway.
    Anyone know what the problem is? Have I "fried" my engine?
    Darcon666's Avatar
    Darcon666 is offline Evil is always around you
    The Wife
    Jun 2010
    At home
    Well you definitely have a leak somewhere.
    Check all hoses and for any cracks in the radiator.
    Get some food coloring and put it in the water(It won't hurt you engine) start it and keep an eye on where it's coming from.
    Good luck with it
    commodore
    Aug 2009
    australia
    id say youve got a decent split in one of your hoses,theres a very good chance you will fry your engine if you keep driving it as is if it hasnt been already check for milky water in the radiator and on the dipstick incase youve done a headgasket or cracked a head and check all your hoses should be pretty easy to spot losing that much water.
    vz wagon
    Aug 2006
    Wild west of Melb
    Quote Originally Posted by Maddog7 View Post
    Hi there.
    Id say the hose that had the steam comin off it has a split in it and change it as for ya engine fair chance ya have cooked it but it still might go can I ask why you dident look for the leak or get it looked at b4 it got to bad ?as for sayin the temp gauge never got over half if the engine has no water in it then the temp gauge cant read hot as it has nothing to read off or maybe4 the sender unit is buggered.
    VT Supercharged
    Oct 2010
    Nathalia
    On my vt i had a small split behind the intake manifold but right in front of the wall shaped like a banana. The hose got weak over time as there is a frair bit of pressure. I watched my temp move the slightest bit the wrong way pulled over an found the smallest amount of coolant dribbling onto my gearbox. Double check that hose it7 only cost $10 an it prevented me from potentially killin me car.
    VT Supercharged
    Oct 2010
    Nathalia
    Definately should be easy to locate...and make sure your not blowing steam out the exhaust...
    VT II S pack
    Dec 2008
    dude that happened exactly the same with my car yesterday, it was making clicking noises when i was accelarating and the engine smoked up, it turned out that the headgasket is gone, done some serious damage ....white smoke was coming out the exchaust aswell and the engine shook heaps. theres was air in the engine where the water goes thats what caused the problem overheated.
    VT Executive S2
    Dec 2009
    same happen to my vt, tapping noise came from under bonnet, car smoked, then cut out, turns out head had blown.
    Claudy's Avatar
    Claudy is offline French Com
    Manual Gen3 VT SS + V6 VT manual turbo
    May 2006
    Perth, Two Rocks
    Or valley cover gaskets, those bolts always get lose
    Gen3 6spd Manual VT SS
    VT V6 Manual turbo
    VT Supercharged
    Oct 2010
    Nathalia
    A lot of ppl (mostly dumb c***s) forget that after replacing or draing that you have to bleed the air out of that small valve located somewhare on the out house of radiator. "Oh, thats what that is". I dont know how many times ive heard that.
    vt calais l67
    Jun 2009
    2 ltrs is a dam lot of water , probably head gasket at the best . if it was being lost externally it would be pretty hard to miss . get it to a mechanic asap .
  1. [VR-VS] How To: Fix the VS V6 4 Wire O2 sensor earth problem – Known Holden Problem
    By ephect in forum Holden Commodore How-To's
    Last Post: 17-01-2012, 11:25 PM
  2. idle problem, very difficult to find problem
    By calais s2 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-07-2010, 10:51 PM
  3. Central locking Sv6 problem. this going to be a problem car??
    By philsv6 in forum VE Holden Commodore (2006 - ?)
    Last Post: 21-04-2010, 10:40 AM
  4. vent problem and horn problem
    By plasmid2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-06-2008, 10:53 PM
  5. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
