Results 1 to 4 of 4
Thread: no gears available
    vt supercharged s pac v6
    Oct 2010
    sydney
    Default no gears available
    hi i have a vt v6 supercharged all standed was driving when it lost gears . its like i have blown a diff but tail shaft is not spinning . shifter is ok and working but no gears. does anyone know what is wrong or has had this problem?
    VS Berlina soon to be 5L
    Aug 2010
    Girrawheen
    have u snapped the drum spline in the gearbox or the output shaft, or convertor troubles?
    2002 VX II Acclaim
    Aug 2008
    something similar happened to me in a VN. drove the car, parked, started and lost all gears. turns out the hose on the trans cooler lines was a tad perished and i lost all my tranny oil. no oil = no gears.
    Check if youve got oil.
    Bushy's Avatar
    Bushy is offline Project ~ VX II ~
    2002 VX II 3.8L
    Dec 2008
    Toowoomba
    Quote Originally Posted by anarklov3r View Post
    happend in my VS also..
    but then also when i was giving in a good old run sitting on about 180ks ( Ops ) i lost all gears also and had to pull over and turn car of for 5 mins then start it again and it was back to normal...
  1. !change of top speed in gears when fitting 3.7 diff gears.!!??
    By slappedvr in forum V6 Development And Modification
    Last Post: 30-01-2010, 09:54 PM
  2. 4.11 gears
    By somerandom in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-06-2009, 10:05 PM
  3. Need help with dif gears
    By VS5lTR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-12-2008, 07:12 PM
  4. Car wont change gears, holds gears, and rough changes
    By pedrotski in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-09-2008, 06:35 PM
  5. gears
    By caminsa in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-04-2007, 04:22 AM
