Results 1 to 5 of 5
Thread: Vx LSD Problem or a Normal thing??
    FPV GT-P Boss 335 & 2000 VX Berlina 5.7lt (toy)
    Jul 2010
    Dalby
    Default Vx LSD Problem or a Normal thing??
    Hi guys, I have a vx berlina with the LS1. I recently purchased an 3.46 Ratio LSD now my question is... when I do a burnout or just take off hard it will leave 2 black marks as it should, but when Im at an intersection turning left or right I take off & both wheels will spin but as soon as I turn it sharp 1 wheel will stop spinning (the one with all the weight) as soon as it straightens up both will light up again. Is this a normal thing? Ive never tried doing a donut as such so I dont know if both will lock up. Even in the wet as soon as I turn its only 1 wheel then both when it straightens. Can anyone help me!!? I dont think its a case of not enough power as it will do a line-locky in 1st, 2nd & 3rd (auto).
    Commodore M6
    Jul 2010
    East Coast
    your diff is probably getting worn
    try a oil change
    if that doesn't work you need a rebuild/reshim or a Kaaz
    Jul 2010
    Dalby
    It should'nt be. Its out of a VZ Maloo ute with only 50,000 k's on it. I guess if its been ill treated it would'nt matter how old I guess. I also put new oil in it when I got it, cost me $130just for the oil & additive
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    one wheeling is a sure sign of either shagged LSD cones, or glazed cones. Either way the LSD needs to be removed to check for sure.... which inevitably leads to... "May as well recond it while it's out"
    To check for yourself... Jack one rear wheel up clear of the ground (other side must be grounded). chock the front wheels up, put the trans in 'N', handbrake off. Grab the wheel (that is off the ground) by the spoke and turn it round. How easily does it turn?
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    VY-Vz had diff issues with utes i think, vy for sure.
LinkBacks (?)
  1. 10-11-2010, 08:27 PM
  1. Weird problem, not sure if normal
    By bennyboy91 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-08-2010, 11:05 PM
  2. simple thing causing a huge problem
    By bradcad in forum General
    Last Post: 04-11-2006, 08:01 PM
  3. Is This Normal?
    By azzfox in forum Car Audio
    Last Post: 31-12-2005, 11:30 PM
  4. NOT normal ...
    By s0sage in forum Jokes/Humour
    Last Post: 15-12-2005, 10:21 PM
  5. Not your normal speedo problem
    By Chuff in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-04-2005, 09:33 PM
