Results 1 to 21 of 21
Thread: VT Fuel Consumption & Gauge Question
    04 VZ Exec, HX Kingswood, VB Comm
    Aug 2008
    Sydney Easter Suburbs
    Default VT Fuel Consumption & Gauge Question
    Hey all,
    VT SII with Supercharged Engine.
    I get anywhere between 19.7L / 100km hard city driving (mostly start stop, lots of acceleration and deceleration) Highway the lowest I can get it with aircon off is 10.1L/100km
    Is this normal ? Mind you it is due for a service.
    Also the most important question.
    Something is F'd with my tank.
    This morning, digital read out said 12.5 L left in the tank & it was showing quarter tank, cool, so i went to fill up.
    @ 39.7L the pump clicked. meaning i technically only had 52.2L in the tank, but isn't it a 75L tank?
    So where is the rest?
    I've tried to trickle fill it right to the brim, the gauge shows about 5-6mm down from full. I've never had it go fully up. So i'm very worried as to where the rest of the fuel is? thats 22L missing!
    Is it possible that someone has had to change the tank and fitted a smaller 60L in it's place?
    Could that even work ?
    Thank you for your help.
    VT Berlina
    Oct 2010
    1TUFVS's Avatar
    1TUFVS is offline High Ambitions, Low Funds
    '95 VS Acclaim
    Oct 2010
    SA: The Defect State
    Fill the car up as much as possible and reset the trip counter, that should give you a good idea as to the amount of KM you're getting on a full tank. Then, check the average range of the Supercharged 3.8 and see if it's remotely correct.
    If it's close to the standard range, i'd be checking the fuel sending unit for faults.
    Aug 2008
    Thank you for the replies.
    I've tried to fill it up as much as I can reset the trip computer.
    I got 500km to a tank which is the normal amount I guess. I've been getting that amount in driving as well, which makes this even more strange.
    So i guess it could be the fuel sender? Which i guess is a very expensive repair.
    What should I do ?
    vt calais l67
    Jun 2009
    i have vt2 sc your consumption sounds similiar to mine . these things love to drink . i got a little under 10ltrs per hundred on a trip from yamba to bris wasn't pussy footin either . cheers
    MikeCuzzy's Avatar
    MikeCuzzy is offline How hard can it be?
    2007 VE Omega 3.6L & 1998 VT Executive 3.8L
    Jan 2010
    Wollondilly, NSW
    500km from a tank is perfectly normal, as is anywhere between 10-20L/100km depending on driving style.
    As far as the distance to empty-litres remaining, VT fuel gauges are by far the most inaccurate form of measurement on the Earth. The best thing you can do is fill the tank to the brim, drive it as far as you feel safe (till the gauge reaches 1/4 or something) fill it back up and work out how much you used and how far it got you to get an idea of how your car is on fuel.
    Is this a new car of yours? If so the low down is this: Holden fuel gauges are notoriously inaccurate, mine is very bad as is the one on my Dad's new VE (though it is marginally better), VT's especially can be iffy. If you are getting 500KM the fuel is getting from the tank to the engine and it is a 75L tank so I doubt it's the fuel pump. I've noticed in mine if I fill it up from half it won't always go all the way to full, even though it is.
    So yes, as I said, these gauges are a bit funky, so long as you are getting the distance from the fuel you put in, I wouldn't worry.
    The New Ride - The Class 2 Shuttle Craft (VE)
    I'll be he comes to get you, some shopping trolley kind of thing, that gets you where your going nice and slow... Well off you go that's fine, the pleasure's all mine.
    When I light the nitro on my HQ 454 Monroe!
    2000 VT S-Pack II
    Dec 2009
    SE Queensland
    Quote Originally Posted by MikeCuzzy View Post
    As far as the distance to empty-litres remaining, VT fuel gauges are by far the most inaccurate form of measurement on the Earth. T.
    Agreed. that electronic thing telling you how much distance until empty is useless...
    eg. Drove from Hervey Bay to Brisbane (3hour drive on highway) and it gave me another 60km of distance in my tank as i drove...did not decrease at all the whole trip, just kept increasing haha
    Beno1982 is offline Beno
    VX SS 5.7L M6 sedan
    Apr 2010
    Clermont
    I have a VX SS and when i fill the tank DTE reads around 860km, however i only seem to be getting between 6 and 700km to the tank.
    Aug 2008
    Thanks again for the replies they have helped a fair bit.
    MikeCuzzy i've had a few vt's and vx's & a VZ and I've only ever had a shit gauge on my VZ and this car.
    I do get fuel range between 10-20L / 100km which i thought is normal as well.
    The digital measurement does show 75L when I have filled up fully, i'm just wondering if this gauge will get any worse and what I can do to correct it?
    But yea I am getting the distance from the fuel for sure.
    LOL JSTCOZ i know what you mean hahaha, thats happened to me before on my VZ, it said I had 0KM of fuel left turns out I still had 12L.
    VT Berlina
    Oct 2010
    I've heard of people getting there fuel sender thing re calibrated I think :$ don't quote me
    MikeCuzzy's Avatar
    Jan 2010
    Wollondilly, NSW
    @mainpath
    Lucky you I seriously feel like I am figuring out how much fuel I have by using the Force.
    I wouldn't worry too much unless it was inconsistent giving readings, i.e. you let it go to 1/4 and it had 30L, fill it up then the next time it had 20 at a 1/4, then the next time 6L or something that indicates the sender unit is a bit funky. But yeah, as I said, so long as the fuel is getting to your engine it boils down to whether you want to fork the coin out for an accurate fuel gauge.
    I drive the same route all the time so I know I've got about 650km till the tank is dry and go off distance covered rather than distance to empty.
    supercharged vt II acclaim
    Sep 2009
    goldcoast
    my vt l67 seems to use roughly the same.. hwy its good with fuel, but around town it sucks ass, ya have to be real real easy on the throttle to get good fuel consumption around town.. a good service will help it out a bit thou..
    as for the digital thing , as said above -its crap...
    if you've had ya fuel pump changed the little float thing may have been bent a bit, so it thinks theres more or less in it. i stuffed mine a little when changed pumps, i bent it or it got bent a little in the post, but its got more fuel than it thinks there is which isnt too bad, will never run out..
    Quote Originally Posted by chargedvx6 View Post
    I meant what I said and said what I meant so if you mean to say I said what you think I meant and it wasn't actually what I meant then that means you mistook what I originally said and meant to be wrong when in fact it isn't..
    my supercharged vt acclaim
    http://forums.justcommodores.com.au/...claim-l67.html
    VT Berlina
    Oct 2010
    My gauge reads low, it says its mid way between half and the 2nd last bar when its only used about 34L taking it to holden to get recalibrated $121
    Aug 2008
  15. #15
    VT Berlina
    Oct 2010
    Will do! i rung Holden at blacktown like 30 minutes ago he said its probably the calibration so they do that first and if they doesnt fix it, its the sender or msomething in the pump
  16. #16
    VT Berlina
    Oct 2010
    Booking it in tomorrow to get recalibrate its pissing me off ive used 46L and its almost at L
  17. #17
    VT Berlina
    Oct 2010
  18. #18
    VT Berlina
    Oct 2010
  19. #19
    VT Berlina
    Oct 2010
    Done, 65 dollars later touch wood it seems okay put i'n 36L it sits on the 2nd bar,
  20. #20
    VT Berlina
    Oct 2010
  21. #21
    VT Berlina
    Oct 2010
    Re calibrated pulled it up abit but im gonna get the sender unit replaced... holden quoted me 550+
    rung my mechanic he quoted me a max of 350
  1. Just a general fuel consumption question
    By kcpwns in forum VY Holden Commodore (2002 - 2004)
    Last Post: 09-04-2011, 05:35 PM
  2. fuel consumption question
    By fergie_vs in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-02-2010, 08:24 PM
  3. Fuel Gauge Question.
    By VXHBD6 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-01-2010, 02:04 AM
  4. Fuel Consumption in relation to Service question ??? - please help
    By scalper in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 05-06-2009, 06:53 PM
  5. Fuel Gauge Question
    By GMTANK in forum Electrical Wiring / Questions
    Last Post: 16-04-2008, 09:20 AM
