Results 1 to 9 of 9
Thread: blown head
    VT Executive S2
    Dec 2009
    Default blown head
    decided to get a replacement engine due to be put in over next couple days from a wrecker. did not get a re-con, just gettin one put in from a vt that had a computer issue and its done 120,000kms. paying 1400, worth risking not getting a re-con or 120 kms is trust worthy enough? im desperate to get back on the road so i didnt hesitate to say "yes" to the only ecotec the wrecker had.
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    is that $1400 fitted
    VT Executive S2
    Dec 2009
    Zeussy's Avatar
    Zeussy is offline SSM11K
    VY Acclaim S2, VH SLE
    Dec 2008
    Central Coast
    Whats wrong with the original motor? Blown/craacked head, or just the gasket?
    If its just the gasket and you know your way around a toolbox it could be easily fixed for less than that?
    VT Executive S2
    Dec 2009
    the head has blown, whole engine is flooded, exhaust spitting fluid and thick white fumes, its completly ####ed car wont even start now as it doesnt produce enough power
    Zeussy's Avatar
    Dec 2008
    Central Coast
    Yeah, but all that could be down to a head gasket...
    Essentially nothing wrong with the motor. Just a gasket... Seriously.
    EDIT: Where abouts are you?
    VT Executive S2
    Dec 2009
    so what would be the telltail sign of the head being blown as opposed to just the gasket? Perth
    Zeussy's Avatar
    Dec 2008
    Central Coast
    Ehh, too far to travel Im over East Coast...
    Mmm, really only pulling the head off and checking. V6 are known for doing head gaskets, pretty common, same with a few other things...
    But, if you pull the heads off, you cantake them to a head specialist/engine builder/reconditioner to go over and check the heads, and make theres no cracks and check they're flat/deck/machine them.
    If no cracks, get it decked/serviced, new gasket, maybe new bolts (if needed?) and put it all back together.
    VT Berlina
    Oct 2010
    Might be cheaper to do that first, might save you a couple of bucks.
  1. blown head??
    By rishey89 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-07-2010, 10:29 PM
  2. Blown head?
    By madsav in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-04-2010, 01:05 PM
  3. Cracked head? blown head gasket???
    By VL_5SPEED in forum General
    Last Post: 09-01-2010, 10:41 AM
  4. Blown head gasket or cracked head
    By ucwepn in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-06-2006, 07:52 PM
  5. blown head?
    By vr_chaser in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-01-2005, 10:29 AM
