Results 1 to 8 of 8
Thread: VX Broken ignition switch, wong start
    VX V6
    Feb 2008
    Default VX Broken ignition switch, wong start
    Hi,
    Wife drove to the local shops, went to leave and the car wouldnt start.
    Turning the key does nothing because I can feel there is no mechanical load behind the switch.
    I can rotate key back and forth , from the accesory position to the start position, feeling no clicks
    or detents and to make it worse its stuck in accesory position.
    I has air bags, so I wondering if this is common, does anyone which piece is broken or will I have change the whole coffee pot in the column?
    Cheers, Archie
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Sounds to me like the end of the barrel (the part that goes into the ignition switch) has broken off. A common problem and it means a new barrel is needed. Disconnect the battery so it won't go flat.
    MY RIDE
    VX V6
    Feb 2008
    Thanks, I have comfirmed that's exactly the problem after I returned to the carpark with af ew tools and now I got the car home.
    New barrel , mmmmmm, definately a new outer assembly, but does the actual inner barrel come out so I can transfer it and use the same key
    or am I up for a new ingition new, then I'll be left with adiffrent door key?
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    A lot of locksmiths sell the barrels because it is such a common problem, they can also code it to suit your existing key.
    MY RIDE
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    replace the whole barrel as they wear out together
    if you (could) replace just the outer eventually it would get stuck again....
    new barrel will have to be coded to key....
    VX V6
    Feb 2008
    Thanks fot the info guys,
    I went down to the local locksmith who sold me a new barrel assembly, keyed to my existing key $100 later.
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    i'd be replacing the switch to as a precaution, because they seem to tighten up, which in turn causes the snapping of the barrel.
    VX
    Jul 2011
    ivanhoe 3079 victoria
    Default VX 2 Ignition Barrel Failure
    I have just had the same problem. If it wasn't for this site I would have been in a lot of hot water. Our key jammed, wouldn't go into ACCESSORIES and so wouldn't withdraw.
    The RACV mechanic and towtruck driver, between them I think wrenched the steering wheel out of lock. When I got the car home and had a look at it I had a lot of trouble getting the whole assembly dismantled. The stuck key prevented the removal of the Immobilizer Ring and so I had to take the two key screws out and pull the door lock reader off the key. Then finally force the key with a spanner into ACCESSORIES position.
    After that things went a lot better. I bought a new replacement genuine key lock assembly from Doncaster Holden for 60 bucks. Thats all I spent. Once you get the lock barrel and sleeve assembled you have to make sure you do two things:
    Put the steering lock in UNLOCK position, use a screwdriver for this.
    Turn the actual ignition switch to ACCESSORIES position. Again, use a screwdriver.
    Finally, remember to turn the key to ACCESSORIES for when you slide in the key and barell assembly.
    Take your time
    Be cool.
    Don't try to force things.
    I have put up 5 short vids on Youtube showing how I did this. Not great quality but still I hope it helps someone.
    The whole lot should just slide in easy. If it doesn't something is wrong.
  1. VS ignition barrel broken. Need to start her.
    By moondog450 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-04-2012, 10:59 AM
  2. Starter motor/ignition switch/neutral safety switch?
    By Drewie in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-02-2009, 08:19 PM
  3. help - ignition broken!
    By hurley in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-01-2007, 10:29 AM
  4. Ignition switch no longer triggering starter relay - what's broken?
    By synoptica in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-07-2006, 01:58 PM
  5. Key Broken in Ignition
    By Rev_neil in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-06-2005, 10:30 PM
Tags for this Thread
