Results 1 to 4 of 4
Thread: how do you get a VU SS fuel filter off??? urgently need help
    VR series 2 commodore
    Oct 2009
    Cranbourne victoria australia
    Default how do you get a VU SS fuel filter off??? urgently need help
    how do you take the clamps off on a VU SS fuel filter??
    i use to go for ford
    but my mates sent me to rehab because i was dreaming that they would one day be at the top
    and now im a proud holden man and i can dream all the time about them being at the top because they never left =]
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Is it the same as VY, etc? Push in the fuel lines and squeeze the little clips in with (I use multi-grips) and they should pull off. Do one at a time, and if you haven't de-pressurised the system like I don't, then keep your eyes and face away!
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    You can get the Fuel Line disconnect tools, they do help, also if the fuel is not de-pressured it makes it much harder too.
    VT Acclaim Wagon
    Oct 2008
    Reduce the fuel pressure by removing the fuel pump fuse, then start and run the engine until it stalls, crank it over for another 10 seconds. This will stop fuel spraying everywhere when you remove the hose. Still, use some rag around the hose to catch any dregs when you remove the fuel hose.
    Push the hose forward towards the filter, sqeeze tangs/clips, remove hose. On the new filter, squeeze the hose clips and slide the hose on the filter, repeat for the other end. Check for secure fitting. Replace the fuel pump fuse and start the engine. Run for 30 seconds, turn off and check for fuel leaks
  1. Fuel Filter and Fuel Line
    By King_berald in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-03-2010, 09:51 PM
  2. Whats the best oil filter,fuel filter and air filter for v6 vp?
    By Timsgmh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-10-2009, 07:56 PM
  3. Fuel Line removal tools for Fuel Filter
    By vxcalais_01 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-09-2009, 09:56 PM
  4. Need Help Fuel Filter
    By Niper in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-06-2009, 12:09 AM
  5. Fuel Filter?? Need help urgently!!
    By d3war in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-08-2005, 08:27 AM
