Results 1 to 9 of 9
Thread: Fan Question (Before I explode @ my mech)
    04 VZ Exec, HX Kingswood, VB Comm
    Aug 2008
    Sydney Easter Suburbs
    Default Fan Question (Before I explode @ my mech)
    Hey all,
    I guess you've all seen my never ending saga over the last few days
    with my annoying VT. So i'm sorry to post yet another question,
    I need to know a simple answer as i've read to many opinions (though search function)
    The fan on the drives side, does it turn on when the car turns on (straight away) or does it turn on
    at a certain temp? On the supercharged 6.
    My Current Situation:
    Only at 104 degrees my Passenger side fan turns on cools the motor down and then the drivers side
    fan turns on for 2 seconds then stops.
    Thank You
    PS: My mechanic is on the firing line!
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    HEY MATE.
    With the cooling Fans, Only One fan spins i believe, When it reaches 104° the fan kicks in.
    Now do a test. Go switch the aircon on and check the other fan to see if its running then.
    Ones for aircon ones for the engine (I think) its been a while since i checked this out.
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Fans wont run until the car hits temp.
    With AC on, Drivers side will spin constantly, with AC off fans will kick in when the car hits temp.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    also check your relay is a 5 pin changeover type, cos its what makes the high and low speed for the fan change... if its not working correctly you will only have low speed.
    Aug 2008
    edals: With aircon on, passenger side fan is on, drivers side doesn't go on at any point.
    If i have aircon off when the motor hits 104C it will turn itself on as well.
    SabbathSS: thats what i thought, but yep as mentioned above, driver side will not spin. it will only for 2 seconds when the passenger side fan turns off automatically.
    Boonz: You mean in the engine bay on the drivers side, yep it's a 5 pin, tried swapping it over with a 4 pin, same crap no fan movement.
    It's an annoying problem isn't it ? also all pins are clean, i took them off one by one (relays that is)
    Boonz's Avatar
    Jul 2005
    swap it with another 5 pin relay... and try again, the high speed fan only comes on when it reaches about 109 degrees too, about the only time the passenger side fan spins
    Aug 2008
    Quote Originally Posted by Boonz View Post
    So your saying that when you turn the car on @ operating temp the drivers side fan does not spin, and unless the engine get to 109 thats the only real time when both are on?
    hummm i need to get my self another 5 pin relay then to test.
    edit: ignore what i just wrote, i just re-read it.
    Boonz's Avatar
    Jul 2005
    the low speed fan comes on anytime the A/C is on, or when the temp gets to about 104, the high speed fan kicks in at 109-110ish, which will make both drivers side and passenger side fans spin at the same time
    Aug 2008
    Perfect answer!
    Thank you! I owe you so much!
  1. vy ss cd mech error
    By polly9 in forum ASR Audio & Electronics
    Last Post: 10-03-2010, 09:51 AM
  2. I need a wire diagram for a Sony Explode
    By Yamama in forum Electrical Wiring / Questions
    Last Post: 05-06-2009, 03:46 PM
  3. Xbox 360, freezing and slowwww, im gonna explode
    By VjamesY in forum The LAN Lounge
    Last Post: 01-05-2009, 12:15 PM
  4. CD Mech error
    By paddyj in forum VY Holden Commodore (2002 - 2004)
    Last Post: 05-09-2007, 11:01 PM
  5. Sony Explode
    By mickaitken in forum Car Audio
    Last Post: 05-10-2006, 01:16 PM
