Results 1 to 6 of 6
Thread: VT Engine Light Coming On And Then When Brakes Are Pressed, Go Off
    holden_4aw_lyfe's Avatar
    holden_4aw_lyfe is offline Tsu Tsu Tsu Tsu
    Twin Turbo Stroked 4.2LT VT Berlina
    Feb 2009
    Default VT Engine Light Coming On And Then When Brakes Are Pressed, Go Off
    hey guys i got a tricky one for ya
    my engine light will randomly come on at any time, but when i tap the brakes it goes off.
    any suggestions?
    Don't Knock My Turbo Lag, It Gives Your V8 A Chance
    vx custom 600RR
    Oct 2010
    check the purge hose it's under the engine cover common problem
    it is pain to get to, if you can fit hose clamps i did after getting LPG fitted problem solved though mines a vx same thing
    brakes uses engine vacuum to assist brakes
    worth a look
    Feb 2009
    thanks ill have a look tonight, post tomorrow on what i find!
    Feb 2009
    checked....nothing with the purge hose seems to be loose...
    vx custom 600RR
    Oct 2010
    are you sure? it took me a good 5 minutes to find the hose and a prick to get to
    look again
    Feb 2009
    definately not the purge hose...what could it be?
  1. VS Ute Engine just fitted but engine light coming on and not going into overdrive
    By MX_Leigh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-10-2010, 04:53 PM
  2. engine light coming on
    By craigs vt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-05-2010, 06:23 PM
  3. Engine light coming on
    By Gunzero in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-02-2010, 10:43 PM
  4. Engine light coming on.
    By Nanos in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-06-2008, 07:30 PM
  5. Engine Light keeps coming on
    By Naughty in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-08-2006, 03:08 PM
