sorry if it has been asked but i could not find it when i had a quick look...
Can i put a LvL 3 Cluster in my 2002 VX Acclaim II
as it has the one that has only one window in it.. and i seem to find more lvl 3 clusters...
so will it work correctly. with out any problems...
or is there other stuff i will need to add to make it work....
you need a tech2 dude to reprogram it from your car
i have one of them snap on tools ( well my farther does ) that i have use before to remove airbag codes n all other codes am i able to use that or does it have to be a tech2 as im not shore is the snap on scanner is a tech2
