Results 1 to 9 of 9
Like Tree3Likes
  • 3 Post By ClairBear
Thread: Vt Calais 98 model headlight issue/
    Vt Calais 98 5.0
    Oct 2010
    Default Vt Calais 98 model headlight issue/
    Hi, If some could help me with this problem it would be much appreciated.
    I have a vt calais 98 model, when i switch the headlights on and use high beams the right headlight dims (almost off) and also the same problem if i switch the fog lamps on the right headlight and right fog lamp dim. has anybody else seen this before?
    1997 VT Calais
    Jan 2012
    NSW Central Coast
    Hi mate, I'm new to this Forum - only just read your post - Did you ever find out what was causing this problem?? I am having the exact same problem with my 97 VT Calais.
    Cheers.
    ClairBear's Avatar
    ClairBear is offline Make the stupid stop!
    VE Omega / Hyundai Getz
    Nov 2003
    SA - The Murder State
    Don't think Bass is going to reply given his profile says his last activity on the forum was exactly a year ago
    Maybe he is still in the garage trying to work it out.....
    Quote Originally Posted by commodore1310 View Post
    Ok, once again ive run aground with a bunch of elitist PRATS who think they know it all, stuff your cars and stuff your forum!
    Quote Originally Posted by one_and_only2004 View Post
    No, driving a v6 engages GOD MODE. Please don't continue the argument...
    VTS5's Avatar
    VTS5 is offline TechJunkie
    '97 VT Spack 5 Speed
    Jul 2005
    Sth.East\Melb
    You guys got wrong or faulty globe/s installed somewhere,check them one by one.I'm always use Phillips globes and dont even remember the last time changing any of'em.
    Attached Thumbnails Attached Thumbnails Vt Calais 98 model headlight issue/-01-jan.-04-23.29.jpg
    1997 VT Calais
    Jan 2012
    NSW Central Coast
    Yeah figured as much, but hey worth a try....
    I have posted my own thread asking about the same problem.... hopefully get a response :-)
    1997 VT Calais
    Jan 2012
    NSW Central Coast
    @VTS5 - Thanks for you help! - The last globe I actually changed was the LHS fog. Is it possible for something as simple as the globe to be causing all of this (esp with the High beams)? How?? Can you please explain? :-)
    Vt Calais 98 5.0
    Oct 2010
    Yeah mate i got it fixed. Turns out the headlights have a separate fuse for each one. One of my headlight fuses was blown and was causing this problem. Hope this helps mate. Cheers.
    1997 VT Calais
    Jan 2012
    NSW Central Coast
    Thumbs up Thankyou!!
    Bass308! You are a legend! problem fixed..... I looked over those fuses a dozen times and didn't even think to check them as I was getting voltage at the lights etc.... anyway... Thanks again mate... Awesome!
    Vt Calais 98 5.0
    Oct 2010
    No problem mate :-) I did the same thing.
  1. Low Beam Headlight Issue
    By TrEnNaVY in forum VY Holden Commodore (2002 - 2004)
    Last Post: 12-06-2010, 05:25 PM
  2. headlight power issue
    By Charg'd in forum General
    Last Post: 30-05-2009, 09:49 PM
  3. Replies: 0
    Last Post: 26-12-2007, 11:34 AM
  4. Headlight Issue.. Need Help ASAP :S
    By azzfox in forum Electrical Wiring / Questions
    Last Post: 01-01-2007, 05:05 PM
  5. Headlight issue
    By azdysb in forum Electrical Wiring / Questions
    Last Post: 31-08-2006, 12:21 AM
Tags for this Thread
