The other night I had to demist the front windscreen, so I changed the selector swtich to that setting. Went to switch it back to the face and didn't work, now it just stays on the windscreen. From what i can gather it's a vaccum problem, but not sure where to look on the VX 2001?.
The fan seems to be a bit noicy as well not too sure how you fix that. Also be interested if I took it to an AC place how much they might charge to fix it ?.
Any help would be greatly appreciated.
35 Views so far = no closing to resolving the issue?. Sorry I checked make that 1 reply me LOL.
Try checking the thin vacuum hose that should be connected at the rear of the intake manifold. This hose often comes off or is perished. That is the easiest thing to check and is often the problem. See how that goes and if not we can move on to other possibilities.
I was a bit reluctant to answer because if I have written this responses once I've written it at least 20 times over the years.
MY RIDE
or it could be the vacuum hose on the back of the aircon control in the dash????
Check out my ride here >>>>My VX Raptor
say NO to chev badges
Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
If there is a slight hissing sound when the switch is in any position besides demister its most likely the directional control valve.. 15buck part its basically a little vaccum tap..
pull the dash fascia off, the heater control assembly is held in with 3 screws and unclip the rod coming from the temp control knob.. you will see the little valve on the back
do what i did when i had the same problem. went down to just commie spares and bought myself a new one! and all globes are working again too which is a bonus!
problem i am having now is turning from cold to heat not working so looks like i have to get in there and rip it out again.....
good luck mate
i proudly use and recommend
Enhanced Automotive - 1/11 Bremen Drive
Salisbury South - 8250 2233
Pushing The Limits In The Performance Industry
Just to let you know guys problem fixed, new vaccum control valve fitted. Total cost including labour $75.00. Thanks to Kmart tyre and auto at Morayfieldi in Brisbane for doing this for me, can recommend them, always professional and fair with price as well.
