Hey Guys.
The other day had to stop very quickly, borderline ABS kicking in. Anyway the oil light beeped then stopped then switched off.
Oil on full mark, no probs there. i did a bit of a search and see commies hate vertical and Gs due to the sump design, so guessing all the oil went to the front of the sump. But still should this happen or not? No error codes or anything. Its only happened once and has not appeared since. Possible oil pressure Sender unit on its way out?
nah my commy does it on extreme braking too, its just what they do
its normal...if the oil gets low it will do it with less braking as well
VR through to VX wrecking in WA, must get rid of these!
http://forums.justcommodores.com.au/...res-vr-vx.html
OK thats what i thought guys, No harm in checking though, oils kinda important lol
Cheers :-)
