hey guys im wondering if the wh statesman door will fit into a vt (the inside skin part of the door). id be keeping my same seats just want the doors
Yes it will. I put WH Caprice door trims into my VX Berlina and it fit no problem. As long as your car has power windows you won't have a problem.
There are 2 types of pedestrians, the quick and the dead
Check out my ride here....
http://forums.justcommodores.com.au/...rlina-ls1.html
do you know if the whole interior fits?? im wanting to swap the dash board and the center console bits and all that. basically i want the cream/tan statesman interior in my vt
they fit straight bolt in.
however the rear seats will have a whole where the seat belt goes through and they will sit a tad higher
The center console and dash etc is a straight swap over, 30 minute job if you know what you are doing. As for the rear seat ... the base is no problem, fits perfectly, but the back is a different story. I had to get it re-trimmed in my car. It is about 5cm short on each side because the Statesmans have the additional panel which is an extension of the door trim (being LWB). There is also two holes on each top corner for the seat belts as they come through the seats on the stato, not from the C pillar. If you know an upholsterer they can do it for you cheap (saving on labour) otherwise some guys charge a fair bit for the extra foam and "effort" required. As accentstencil said, have a look at the link to my ride in my signature below and you can see the photo's of it in my car.
My suggestion (if you can get matching leather) is to buy a back from a VX Calais and base from WH Statesman!! Either way it will require a bit of effort, but nothing is impossible!
cheers for that, great detailed description exactly what i needed to know![]()
No problems mate. Good luck with it.
Dose the wh statesman rear window fit the vt commodore??
