Results 1 to 10 of 10
Thread: Air Bag Light.
    2000 VT S2 Olympic Ediiion
    Feb 2010
    Default Air Bag Light.
    How do I get rid of the airbag light on my dash or even why is it there are my airbags faulty?
    You can lead a fool to wisdom but you can't make him think.
    96 VS SII 5.0 Calais
    Apr 2009
    Melburn
    you cant. youll need an auto elec to reset the computer and that will remove the light. if it reappears it may be a more involved problem.
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Airbag light is a common problem on VT's. Resetting the pcm wont achieve anything. The light is usually caused by a faulty srs module which is located under the centre consol or the clockspring which is fixed to the back of the steering wheel. The airbag itself is usually not the cause of the fault. I'd be replacing the srs module and if this doesn't fix it then replace the clockspring.
    Feb 2010
    Thanks guys not something i will be jumping on today but in the near future yes.
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    If the car is for road use then it is likely that your vehicle will be unroadworthy until such time as the error code related problem is reso;ved. As your vehicle was built with air bags in order to comply with ADR's (Australian Design Rules) in all probablity they may no longer function (as designed to do) in the event of a collision. Also, consider the occupants of your vehicle who may no longer be afforded the life saving intervention of an air bag if circumstances are such as to trigger it/them.
    DLFHUB666's Avatar
    DLFHUB666 is offline Got Milk ???
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    i know the vx had a common fault where a wire or something came loose an the airbag light would come on happen to my car took it to holden 5mins later fixed an they didint even charge me.
    Take it easy...But do take it...
    Do not argue with an IDIOT.
    He will just drag you down to his level an beat you with experience
    Some people take me the wrong way, Like smacking up Marijunna.
    VX S
    May 2009
    I had the same problem and turns out the airbag module was faulty. Was quoted $470 for a replace and install. Does anyone know if this is a rip off or know where i can get a better price in melbourne?
    Did have VS Berlina now have VT Berlina
    Mar 2010
    Cockatoo Vic
    the same thing happen'd with me just take it to holden and they reset the computer and it was gone and it didnt cost anything
    VX S
    May 2009
    I had it reset and the light came back on.. Thats when i got the $470 quote and was told it was faulty. Has anyone purchased these off ebay and fitted themselves?
    DLFHUB666's Avatar
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    IMO airbag jobs should only be done by Professionals.May be chaeper to buy the part from ebay an see how much they charge just for an install.
LinkBacks (?)
  1. 16-08-2011, 04:29 PM
  1. ENGINE light, ABS light, TRAC OFF light AIRBAG light and OIL light
    By jamierawr88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-10-2011, 09:06 PM
  2. HELP Engine Light / Transmission light and rough gear changes
    By flash20005 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-10-2010, 03:34 PM
  3. Engine stops, fuel light on, battery light on GOODBYE
    By scarletx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-06-2009, 03:43 PM
  4. vr calais head light and interoir light brake problem
    By lestat2220 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-08-2008, 01:38 PM
  5. Berlina/Calais/Statesman Roof Inteior light into basic model with standard light
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-08-2008, 10:07 PM
