ok lesson lernt dont let a mate do your firing order why you go put tools away
so i need the firing order of a S1 VT berlina v6 asap i searched around and found digrams like
the plugs being
2 4 6 on the drivers side and 1 3 5 on the passenger side which i understand,then with underneath it saying coils 6,3,2,5,4,1
which i dont understand
anways thanks in advanced
the firing order for an ecotec is 1,6,5,4,3,2. Just follow the pic below.Coil terminal 1 to cylinder 1 and so on.
cheers man will do that asap
also when i was taking the 2,4,6 the plastic wrap sh!t was that brittle it snapped and cracked dose that HAVE to be on?if so what can i do alternatively?
The plastic tubing over the plug leads always goes brittle and falls apart.Mine went on my VS a couple of years ago now.I just run the leads through where the plastic tube used to go..
cheers thanks heaps man appreciate it!
No worries.Cheers.
