Results 1 to 4 of 4
Thread: Vt throttle position sensor
    VZ Ute
    Sep 2010
    coffs harbour
    Default Vt throttle position sensor
    If there is a problem with the throttle position sensor, does it cause the engine light to come on?
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Maybe not because I've just had a TPS error code cleared but the engine light has not been on. I'm going to have the codes checked again to see if it has logged another TPS code.
    MY RIDE
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Depends on the problem, DTC19 TP sensor stuck, DTC21 signal voltage high, and DTC22 signal voltage low, are all supposed to turn on the "Check Powertrain" light in a V6.
    Vy ss s2
    Nov 2010
    Townsville Queensland
    i had my throttle position sensor fixed in my s2 vt v6 recenly. and yes it made my engine light come on. freaked right out. cheap job. easy to fix.
  1. Throttle Position Sensor Error 19.
    By Deneo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-04-2010, 07:08 PM
  2. Throttle Position Sensor on VN V8
    By vq~gangsta in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-05-2007, 03:54 PM
  3. Throttle position sensor (I think) is stuffed
    By DavidPartay in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-11-2006, 08:52 AM
  4. throttle position sensor
    By zx9 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-07-2006, 05:13 PM
  5. Throttle position sensor. How Much?
    By ElDubya in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-08-2005, 12:58 PM
