Results 1 to 7 of 7
Thread: vt lvl 3 cluster conversion
    slepar's Avatar
    slepar is offline omg duz it like...dose??
    vn ss
    Mar 2007
    Default vt lvl 3 cluster conversion
    is it possible to put a level 3 cluster into a vt ss wich only has the 1 window cluster? do i need to modify anything? ive searched and only found one thread were a guy had a vt ss v8 and put a vx v6 cluster in and apparently it worked but i want more confirmation than that before i waste money buying and cluster to find i need to spend hundreads to get it to work
    all help much appreciated
    doin skids for the kids and doughnuts for the grown ups
    2002 VX II Acclaim
    Aug 2008
    You can swap the clusters around, without an issue. a VX lvl3 cluster will work in a vt lvl1 cluster car. Wiring is all the same. You jsut need to plug the car up to a tech2 (either at auto elec or holden) to program the cluster (v6/v8) rim size, tank size, etc.
    slepar's Avatar
    vn ss
    Mar 2007
    ok well the vt is a 5.0 so what happends if i get one from another 5.0? will i still need to hook it up to the tech 2?
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by slepar View Post
    The clusters need to match your cars features - number of air bags, climate control - A/C. Gear box, diff, rims/tryes. All of which can be set via a Tech 2 programmer gizzmo. If you plug it in to test the cluster it will code an error for sure and then you will have to visit the tech 2 people.
    Many people have done the upgrade - easy done - but it is a 2 step process. Buy the gluster and then get it matched to your car.
    and 3 Dangerous non ABS VN's
    slepar's Avatar
    vn ss
    Mar 2007
    so should i buy one then plug it in then take it to somewere they have a tech2? or can they program the cluster out of the car?
    slepar's Avatar
    vn ss
    Mar 2007
    also do u know the average price for the tech2 proraming?
    88GreenVN's Avatar
    Jun 2006
    Nar dont plug it in until you are ready to program. It can vary as to cost from $25 for a simple airbag fix to $150 for a complete re program by a VDO bloke. Phreddy may be able to help or Dr Bob Rob's Creative Calibrations. I know I have sent a VT L3 for programming to Dr Bob with no problema nd the cluster woked a treat.
  1. VB-Vh SL\E Dash Instrument Cluster Conversion
    By Pub247 in forum Holden Commodore How-To's
    Last Post: 13-03-2011, 08:47 AM
  2. vp l2 to l3 cluster conversion help needed
    By kitted vp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-09-2010, 12:18 AM
  3. L3 cluster conversion
    By te_rarawa in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-05-2010, 09:52 PM
  4. stage3 cluster conversion wiring????
    By njb1988 in forum Electrical Wiring / Questions
    Last Post: 31-10-2009, 05:05 PM
  5. VT Calais Cluster Conversion etc
    By SamssuperVT in forum ASR Audio & Electronics
    Last Post: 12-09-2009, 10:47 PM
