did the regas cost $80, and then he told me the compressor is dead,says $600 to get the second hand + labor.
Should I get a new compressor or not?
how much if i replace a new compressor in hold dealer?
I would go new, but not from Holden.
Ronald Reagan (1986)
i had mine replaced by Holden last year, and all of the parts required including a new compressor was only $600.52. No way secondhand should cost that much.
I've seen new Delphi OEM compressors on the net for less than $400.00. If you have a series 1 VT get the compressor changed to the type used on VT series 2 to VY as they are better.
A brand new compressor fitted and gassed woudl be in the order of $600. I have seen second hand compressors for about $90 so a good second hand one fitted and gassed should only be around $300.00
If you are planning to keep the car for a while, I would buy a new compressor. I had mine replaced a couple of years ago at a specialised air cond. place.
IF I do want to get a new compressor, and fitted.
Where can I get the compressor , i am in adelaide?
and where to get it fitted? any mechanical?
i heard holden quite expensive,
BTW it's VT SEries 1
These threads may give you some more info. I had the same problem about this time last year.
air con comressor
Air con hissing
