Results 1 to 9 of 9
Thread: Multiple Problems With VT Berlina - Advice/Direction Welcome...
    1997 VT Berlina
    Oct 2010
    Berwick, VIC
    Default Multiple Problems With VT Berlina - Advice/Direction Welcome...
    Hey Guys,
    Brand new to the forum, i was hoping I could get some advice on having my Berlina repaired..
    The problems are as follows:
    - Climate control only blows out windscreen (demister) vents.
    - Climate control fan only works on high setting (its either on high or off)
    - Drivers seat back adjusting winder broken.
    - Drivers seat back panel loose.
    I have done a little research on the climate control issues, and i figure that I am not capable of the repair job, so i best take it to an auto electrician.
    I thought about removing the drivers seat and taking a look at the winding mechanism, but then i read that tinkering with the drivers seat can lead to the air-bag being deployed... and i am not game to try. Can anyone recommend what type of repair shop i should visit to get the seat adjuster repaired?
    With the front seat back panel... the problem is that one of the white round clips holding the back panel on is broken, i can fix and fit this myself... but i have no idea what the little white clips are called, or where to get them.
    Thanks for taking the time to read... any help and/or advice is greatly appreciated.
    Thanks guys.
    Dz811's Avatar
    Dz811 is offline Just some p-plater
    VZ SV6 M6
    Sep 2009
    i only know that the first problem is caused by either a faulty or not plugged in vacuum hose, its a really small hose that comes out of your firewall in the engine bay, but i only know where in the VZs. It may or may not affect problem number 2.
    so im not much help
    Quote Originally Posted by QuickVRII95 View Post
    I Outsmart Defence Force Psychologists... My IQ "IS" Also Over 165.....
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    1997 VT Berlina
    Oct 2010
    Berwick, VIC
    eyy, thanks for the reply mate. i have read that a faulty vacuum hose can be one of the causes, apparently it could also be the solenoid pack or the vacuum tank. i believe faults with any of these parts can cause distribution issues.
    cheers.
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    hmmm...
    vacum hose (look at righ hand rear of motor small black hose)
    fan only works on high (suspect fan speed resistor under glove box is two screws to replace not hard)
    drivers seat see a holden parts shop and tell them they will know what part numbers you need off by heart)
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Models with climate control have don't have a fan speed resistor but a Ventilation Motor Control.
    Disconnect the battery before working on the seat to avoid any airbag problems. If you have the stock radio you will need the PIN when you reconnect the battery.
    MY RIDE
    1997 VT Berlina
    Oct 2010
    Berwick, VIC
    thanks for the replies guys... i finally took it to the auto-elec. and while they did fix the fan speed issues... they only half fixed the distribution problem.
    most of the time i can get the air to flow from where i want (except face vents), but it appears it doesnt always work.
    i will try and describe what works and what doesnt.
    - demister vents - always works on all fan speeds.
    - face vents - only sometimes works, and only when air-con is not recirculating. it will never only come out of the face vents, it seems half the flow will come from face vents and half from windsheild/demister vents.
    - floor vents - works most of the time, but only when air-con is not recirculating.
    pretty shitty repair job. i realise that it can take a few minutes for the air-con to act on the changed settings (i think you can hear the pressure change in the solenoid bank)... but ive driven around for up to 20 mins waiting for flow to go from demister to face.
    thanks for any help dudes.
    VX Series 1 Berline wagon 3.8L
    Jul 2008
    we have a vx berlina with the same ventilation problems. I might try the instructions given here -> Repair of VT Variable Speed Fan Control Unit <- to see if I can fix the fan speed problem myself. Otherwise, I'll have to get a new ventilation motor control from Holden.
    As for the demister/face vents problem: ours suddenly decided to play up right at the start of a long driving holiday. We would only get demister or face vents regardless of settings, and it would switch itself between the 2 depending on whether we were accelerating/going downhill or decelerating/going uphill. I've temporarily "fixed" it by tying the vacuum solenoids to face vents so that the family gets airflow. If I can find the vacuum hose in the engine bay, I might pull it off and blow some air through it under water to see if it leaks....
    Jul 2008
    I got the transistor from futurlec in the mail today, and tried to repair the unit. unfortunately, I think I may have damaged the circuit board beyond repair in the process..... so i'll have to get a new unit from holden.
    Mick1988's Avatar
    Mick1988 is offline W.A. Cruise Moderator
    Too many to list......
    Apr 2008
    Perth, Western Australia
    Quote Originally Posted by lamensterms View Post
    Sounds like you have a vacuum leak. Pretty easy to look at yourself if you take the bottom of the dash out on the passenger side.
    Fan speed resistor. Source one from a wreckers or get an electronics shop to source one. Auto elec will charge you a fortune.
    Your car is a 1997 so it doesn't have side impact airbags. Just disconnect the battery for at least 20 seconds before you start removing the seat. The winder is a mechanical assembly so should be easy to diagnose and repair. The back panel is probably clips that can be replaced or modified.
    VX2 Executive Sedan - 3.8L Auto (for now)
    VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)
    VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
  1. Multiple problems with my VT need advice!!!
    By My99VTACCLAIM in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-03-2010, 09:20 PM
  2. Multiple problems + stuff needed for my Berlina
    By vl_2010 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 23-12-2009, 03:18 PM
  3. i've got a few problems and need advice
    By manual crazy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-01-2009, 03:11 PM
  4. Transmission problems - advice
    By Clacker in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-11-2008, 09:27 PM
