Results 1 to 15 of 15
Thread: Question????? - calais roof wiring harness
    MR_VX's Avatar
    MR_VX is offline Forced to be Fast
    VX S pac SII Raptorcharged
    Mar 2009
    Townsville, Qld
    Question Question????? - calais roof wiring harness
    hi i did post in the electrical wiring/ question thread but no help.
    I installed a calais roof wiring harness along with the rear country lights and calais doom interior light. My question is why has the black/blue wire from my old (s pac loom) been replaced with a (purple wire???) what does it do? as it stops at the plug next to the drivers seat where the loom plugs into. Ive just installed the vy sunglass holder (roof console) and want to find out how to wire it up to a calais doom light
    PLEASE HELP?????????
    Check out my ride here >>>>My VX Raptor
    say NO to chev badges
    Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
    For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
    vx custom 600RR
    Oct 2010
    the black/blue wire is a switched to earth wire and the violet (not purple) wire goes to the dome reading lights
    have you got part numbers for the looms i'm doing something similar
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    Quote Originally Posted by oska View Post
    thanks. so what does the "violet" wire actully do?? I can see its at the calais dome light but its not hooked to any thing at the plug next to the drivers seat where it gets pluged into the reat of the car harness, from there and back under the dash theres noting so the violet wire isnt doing any thing.
    all the lights work, the only problem is the main globe in the calais light isnt working with the switch " off-door-on" it just stays on until you lock the car or start the car. how do i get the switch to work again as normal????
    Im trying to find out what wires are what so i can wire up my vy sunglass holder i installed.
    oh and ill have a look for the part nnumber for you.
    vx custom 600RR
    Oct 2010
    ok the violet goes to the BCM so maybe you need a higher level one
    isn't the dome light on a 30 second timer? cos if it's turning off when you lock or start the car it's probably working as it should
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    arrr righto then thanks for that. Ill just discard the violet wire and leave disconnected and alone.
    Hot-Rod's Avatar
    Hot-Rod is offline SuPaFlY -LiV3 Surviv3 Di3
    VX Commodore Series 2
    Sep 2005
    Oz
    Mr VX, if you continue to use the calais roof harness the centre light will never work with the buttons, on - off - door. it will just be door no matter what you do with the switch. I had the same problem when I tried to install with calais/berlina roof harness. I ended up using my executive harness with four wires. Spliced into wires for the rear courtesy lights as well as vy sunnies holder. However the way I have it wired i am unable to use individual light switch buttons on the sunnies holder, they do nothing, can still use normal switch to turn on and off both lights though so i am satisfied.
    00 SS M6/79 chev Monza
    Mar 2005
    i did the same thing ,only issue i have is the auto off no longer works if the door is open for more than 30 mins ,
    Mick1988's Avatar
    Mick1988 is offline W.A. Cruise Moderator
    Too many to list......
    Apr 2008
    Perth, Western Australia
    You cannot use this harness without the LUX BCM. As stated previously the center dome light will just always remain in the door position no matter what you do with the switch. I have successfully done the conversion in my wagon however. I used the calais rear courtesy lamps and the standard executive dome light. I used the Calais roof harness but chopped the wires and changed them to the correct order so everything was correct for the dome light. Works mint.
    VX2 Executive Sedan - 3.8L Auto (for now)
    VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)
    VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    Quote Originally Posted by Mick1988 View Post
    how did you wire yours up then?????
    vx custom 600RR
    Oct 2010
    i've just bought a map light and have modified the wiring with 2 relays and 2 diodes for it to work as factory fitted with the "on- car- off" and map switches to work
    Mr VX the map light has 2 diodes in the wiring when i first got it i was trying to work the wiring out and not realising that there were diodes in the wiring i actually destroyed them so check the ones in your light
    vx custom 600RR
    Oct 2010
    this is the wiring without the relays as they make the switch work as it should
    blue/black is earth
    yellow/green to red/black door trigger
    orange/black to green constant 12 volts
    the 3 wires on the map light switch RED BLUE WHITE
    off position no contact "open"
    door position RED to BLUE "closed"
    on position RED to WHITE "closed"
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    ill give it ago on the weekend thanks
    vx custom 600RR
    Oct 2010
    i'll do a how to with the relays diagram so they work as factory fitted for VT VX as it seems to be a popular mod
    cheers David
    Mick1988's Avatar
    Apr 2008
    I chopped the purple wire and sliced it into the black wire so it would ground the system. Then I cut and rewired the plug so that the pins on the dome light plug married up to the pins on the plug in the pillar. So basically each system could operate separately in it's intended way of the one loom.
    Ive got the wiring diagrams here and from that I could work out which wires to solder where if you like.
  15. #15
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    cheers David
    I think that would help alot of people out
    Thats would be great to have a look at please send it to me.
  1. [QLD] WTB - VX berlina/calais roof wiring harness
    By MR_VX in forum Swap / Wanted to Buy / Trade
    Last Post: 10-10-2010, 06:38 PM
  2. VK wiring harness question
    By DANNY8 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 10-09-2010, 08:23 AM
  3. wiring harness vp calais taillight
    By romez in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-06-2010, 02:39 PM
  4. replacing sections of wiring harness question
    By boothead in forum Electrical Wiring / Questions
    Last Post: 23-04-2008, 09:33 PM
  5. vp calais wiring harness
    By Zuicider in forum V6 Development And Modification
    Last Post: 03-02-2007, 02:22 AM
