Hi, I have been having constant problems with the link pins I have installed on my vt, which has FE2 suspension.
I have had to replace them 3 times in the last year and am always having some sort of noise coming from them, once one even snapped off while I was driving.
I have been using the aftermarket ones,
i was wondering is there ones specially compatable for FE2 suspension?
Any help would be great, thanks.
what brand are you using? sometimes if there over tightened they can wear out or split the bushes, and worse case snap.
Lowered suspensions (like FE2) place more strain on the link pins and bushes. You get what you pay for and the cheap eBay items don't last. Try the Z-shaped Nolathane heavy duty link pins and bushes - part number 42997A. If you are financial you could try their new ball joint link pins 42997AX.
I call bs. I have my car lowered on super lows at the front and ultras rear. Bought a set of nolathene sway bar bushes and the z shaped link pins for just over 20 bucks and there still going 6 months later with no wear. Nolathene is nolathene there isn't that much difference between them. In fact I would almost go so far as to say there all made in the same factory coloured different and rebadged.
im running stock link pins with i think super lows in my wagon, there constantly bending, i get noises and knocks from them a bit, ill be changing to the z shaped ones in the next few weeks,
i could see the stock ones snapping, cause there only like 10mm diameter and there really soft, a quick tap with the hammer to straighten them normaly
