Title pretty much says it all. just after an idea of how much it should cost to fit the following?
MACE 25mm manifold insukator
10psi yella terra press on pulley / oversized idler pulley to fit with standard belt
1 5/8 - 2 1/2 extractors (flanges), 2 1/2 inch metal cats (flanges), hsv twin 2 1/4 inch exhaust
91c hi-flow thermostat
1.95 yella terra roller rockers
4" Maf piping, Maf relocator, yella terra cold air intake
XU6 chip
Laser cut heat sheild
Colder plugs pre-gapped to 1.0mm
Redirect transmission lines
Corvette 2nd gear servo
Possibly Billet 2nd and 4th gear servos instead of corvette
Transgo stage 2 shift kit
Local shop has given me a rough price of 1500 and up...
Depending if I also want the trans done and in which direction I want to go with it
Thanks guys.
