Results 1 to 4 of 4
Thread: Coolant overflow bottle hose bubbling got me f'd
    87LAG's Avatar
    87LAG is offline BOOSTED 6 FTW
    VX S S2 AUTO RAPTORCHARGED
    Apr 2010
    THE SWITCH
    Question Coolant overflow bottle hose bubbling got me f'd
    Hey all got my vx s s2. when i pull up and turn the car off the hose between the radiator and the overflow
    sounds like its bubbling or steaming up for some reason i really cant figure out i have a new cap on there and it stopped but now is back two weeks later but not as bad. the thermostat is about 12 months old 81 degrees
    one from v6 performance.
    any info would be good and yes the system has been bled a couple o times at the top
    cheers
    2002 VX SS
    Oct 2009
    ACT
    Not an expert on cooling systems but I wouldn't be worrying too much mate, just so long as it's not running hot and the radiator cap doesn't burn you badly when you touch it after a good drive.
    Make sure there's no air locks in the system and make sure there is some fluid in the overflow so it can vacuum suck it back in when it cools down. You can always put more than enough in the over flow, what it doesn't need it'll just dump when it's hot.
    Also do a basic check on the whole system hoses, water pump ect for leaks or just general wear and tear. I know for a fact the top radiator hose always slowly slips off on ecotecs. So make sure its on properly. Quick check for the rad cap to see if its working, press the pressure valve in and see if it does it with a bit of force and not needing a vice to press the valve down, then pull the vacuum valve out and see if it comes out easy.
    Also to be on the safe side just keep another stock thermostat around, they are like 7 bucks for a genuine one, it's worth 7 bucks to just test.
    If you really want to be picky re bleed your system. Sometimes you get tiny air pockets they wont blow a rad hose off but can always just be there.
    Good luck buddy hope any of these wild shots help.
    Commodore M6
    Jul 2010
    East Coast
    87LAG's Avatar
    Apr 2010
    THE SWITCH
    wouldn think so if head gasket u would have oil in water or visa versa u would think. and this only happens every couple of days... and has never got hot...
  1. VS bubbling out of overflow
    By Z2TT in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-10-2010, 05:38 PM
  2. Blowing out Coolant from overflow bottle!
    By wiseman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-03-2010, 09:23 PM
  3. Cleaning coolant overflow bottle
    By tr3nt in forum General
    Last Post: 02-12-2009, 07:23 PM
  4. coolant overflow bottle
    By bj42turbo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-07-2009, 06:21 PM
  5. Changing Radiator Overflow Bottle to a Washer bottle
    By nick88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-10-2006, 02:12 PM
