Results 1 to 5 of 5
Thread: Supercharging ecotec help
    JGlinatsis is offline Ratty
    Vr Executive 3.8 V6
    Apr 2009
    Default Supercharging ecotec help
    Hello I have been asked to supercharge my bosses car at work and I have never really done one before so I'm asking if someone can wright a step by step instillation guide on how to do it he has all the bolt on's pulleys headers.
    I know it's a simple bolt on kit but I don't want to go in blind and do something wrong or the hard way so it would be awesome if someone could do a small Gide for me please and thank you
    VX S S/C & BA XR6T
    Feb 2009
    does he have the supercharged heads ect.what parts exactly do you have at the moment?
    Vr Executive 3.8 V6
    Apr 2009
    He has everything for it
    Headers and all i just need to know what I'm doing it looks pritty straight forward
    Just need to know the order to put stuff on
    Or if there is anything I need to know like what pound boost to start off with
    How to install the control for the boost stuff like that
    Do I need to add anything to the loom or anything?
    VX S S/C & BA XR6T
    Feb 2009
    What models is it,auto or manual?
    Do you have the metal gasket kit?Dont use the plastic ones.
    Install to control the boost is easy.The s/c V6 comes with a boost controller mounted on back of passanger head.Wires and a few vac hoses go into it.Start at the stock or 87mm pulley that gives around 9-10psi,5-6 is factory.
    Finding a s/c loom would be the way to go then burning the s/c tune into your BCM/ECU for everything to speak to oneanother.
    Replace the s/c coupler before installation aswell as the oil in s/c.TTT Performance has all of these at a good price,speak to Mark.
    Order would be....
    -Install loom
    -Heads
    -LIM(manifold s/c)
    -Supercharger,Ubend,Bypass valve,Throttlebody,Intake piping,MAF,CAI/Airbox,Air temp sensor
    -Accell/cruise bracket,Accell/Cruise cables
    -Headers,Coolant pipe,Downpipes,cats,exhaust
    -Harmonic ballancer,Tensioners,Pulleys,Altenator,Coolant O'rings(Alt bracket youll see)All the front accessories basically.
    -Fuel rails,Injectors,Pump ect
    -Engine belt the s/c belt.
    Ill update it later for you.
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Wait up, is this a bolt on side-mount kit, or an L67 conversion? Karlos post only counts if your doing a L67 conversion. If its a side snail it should come with instructions and if it doesn't than call the manufacturer and I'm sure they will send a copy.
    Ronald Reagan (1986)
  1. Raptor Compound Supercharging for ECOTEC
    By Raptorsc in forum Raptor Superchargers
    Last Post: 17-05-2012, 11:11 PM
  2. Supercharging
    By ducatis in forum V6 Development And Modification
    Last Post: 21-02-2010, 03:31 PM
  3. Supercharging My Ecotec
    By Kernal in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-09-2009, 02:10 PM
  4. supercharging a stock vt ecotec
    By Vt_vic in forum V6 Development And Modification
    Last Post: 15-04-2007, 08:05 PM
Tags for this Thread
