Results 1 to 11 of 11
Thread: DFI module?
    VZ
    Oct 2008
    Default DFI module?
    hey guys,
    i have a VT calais and lately it seems to be missing intermittently and also its hard to start..have changed leads and plugs and even tried swapping new coil packs..but still same problem..
    do you reckon it could be the DFI module?
    i wouldnt mind picking one up and throwing it in..is there a FAQ or can someone explain how to change it over?
    the car only has 130k on it..
    VZ
    Oct 2008
    anyone??? im sure someone out there could help me? can anyone tell me how to change it?
    VT 3.8ltr Berlina Next Car: VZ Calais or VY SS
    May 2010
    do you have oil in the coolant reservoir? could be an inner inlet manifold gasket which may leak into the injector rail ?
    VZ
    Oct 2008
    nah i dont..but i would appreciate if someone can explain how i can change the DFI module!!??
    180sx
    Nov 2009
    I thought you just remove the coilpacks and then the DFI lifts up and unplug it. Not 100% sure though.
    VE S2 SV6
    Nov 2009
    Quote Originally Posted by jamesjgts25t View Post
    Thats about it. It doesn't get any easier
    VT V8 Calais
    Mar 2007
    Have you tested your battery? My VT was mucking around on startup for the last few months, then the battery died, swap it over and now startup is good as new.
    50LTRv8
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    DFI module is held on by two bolts underneath it, take them off, unscrew the little bolt holding the wiring connector on and done.
    Ronald Reagan (1986)
    Lewie's Avatar
    Lewie is offline B Cast and flat topped!
    Very thirsty VT & VH project under way! YAY!!
    Nov 2006
    Nowra, NSW
    Have you changed the DFI module yet? I'm still having problems with mine. Just wondering if you have any result yet.
    Thanks.
    "Please contact the Administrator if your date of birth has changed." JC Forum. Profile editor.
    VT Berlina
    Oct 2010
    replaced my DFI i module and the 1-4 coil, the coils come off, the casing comes on then you disconnect the module and reverse it and check it..
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    to find out if its the dfi module just switch coil packs around and use plyers with rubber handles and take the leads off if the coils dont work in the one spot, like say where the 1-4 coil pack sits then its the dfi module
    once the coils are off from memory theres 2 clamps holding it in place.. and just so you know its a bitch to get back on
  1. interchaning Vy s1 berlina climate control panel/module with VZ module
    By mudmutt in forum VY Holden Commodore (2002 - 2004)
    Last Post: 24-04-2010, 02:54 PM
  2. FS [VIC]: power arial module and centrol locking module
    By georgeonboost in forum Parts And Other Items For Sale
    Last Post: 24-09-2008, 06:41 PM
  3. module
    By lurkin308 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-12-2006, 09:17 PM
  4. Dfi Module
    By brad_m_is in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-11-2005, 05:14 PM
