Results 1 to 8 of 8
Thread: VT Warning Lights ,Starter, Window message
    VT Acclaim
    Nov 2010
    Default VT Warning Lights ,Starter, Window message
    I am having problems with my vt V6 First All the warning light came on, Then I was receving a service error message, Then the starter would not operate. Now The starter sometimes operates and the egine fires but will not run. Can anyone help Please
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Is the security light in the mode switch flashing while you are trying to start it?
    MY RIDE
    VT Acclaim
    Nov 2010
    No security light not flashing when trying to start but sometimes engine stars, Occassional serv error in windoow
    vx s pack II
    Jan 2010
    aLKIDA
    First of all check for fault codes.
    For all the warning lights coming on it could be the ABS module if fitted
    VT Acclaim
    Nov 2010
    Thanks but dont have fault scanner. Suspect ABS module but because of cost need to find a way to Isolate that. What is cost of scanner and where can I obtain one?
    HSV XU6
    Mar 2010
    Gold Coast
    would any one know where and how to pull or disconnect out the warning beeper for the handbrake?
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by Davidcurley View Post
    You can check the codes without a scanner simply by following the instructions in this link: Checking error codes VT/VX
    MY RIDE
    vx s pack II
    Jan 2010
    aLKIDA
    you dont need a scanner just bridge pins 5&6 on the diagnostic located under the drivers side dash. Search the forum. seek and you shall find.
    could be a lot of things making your car not start.
    Inhibitor switch if auto,CAS,Factory security,Relays,PCM, and so on.
  1. Service Vehicle Soon warning message
    By Calaber in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 22-03-2009, 05:51 PM
  2. Check Powertrain warning message
    By Luke0011 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 05-03-2009, 01:41 AM
  3. All warning lights come up
    By eeugene in forum Electrical Wiring / Questions
    Last Post: 19-03-2007, 09:21 PM
  4. VU Warning lights.
    By TJK-R in forum Electrical Wiring / Questions
    Last Post: 04-09-2006, 04:59 PM
  5. warning lights
    By nathsvrbt1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-12-2005, 11:28 PM
