Results 1 to 16 of 16
Thread: My air con has lost it mind!!
    99 VT Sedan
    Feb 2010
    Default My air con has lost it mind!!
    Hi all
    My air con seems to have lost its mind
    When the air con is on hign and on the dash...It will work for a few minutes than by itself just go to the windscreen
    How can i fix this???
    Thankyou
    VX 'S' S1
    Apr 2005
    South East,Victoria
    The controls for the vents and screen are vacuum operated , maybe there is a leak in one of the hoses
    99 VT Sedan
    Feb 2010
    Quote Originally Posted by Dayvo View Post
    How do i find this leak??
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Stick you ear close to the control and hear if you can hear any hissing coming from it . ( i don't mean to literally stick your ear to it but you get the idea )
    VT V8 Calais
    Mar 2007
    99 VT Sedan
    Feb 2010
    Quote Originally Posted by 50LTRv8 View Post
    Is this when you use the throttle say up a hill?
    I do alot of city driving can't realy remember if its when throttle is pressed
    What could cause this with the throttle??
    Please tell me more??
    vx s pack II
    Jan 2010
    aLKIDA
    Could be the one way vacuum check valve.
    Located near the firewall right behind the motor.
    You will see a skinny hose on the back of the inlet manifold follow the hose and you will see a white valve.
    03 vy calais L67
    Moto X Champion!
    Mar 2009
    Townsville, QLD
    mine sorta does the same thing. on long highway drives it changes itself to the screen. and changes back when i overtake.
    99 VT Sedan
    Feb 2010
    Quote Originally Posted by drift-it View Post
    Does your car only do it when its on hi???
    VT Calais
    Mar 2009
    SA - Victor Harbor
    my calais does it whenever i accelerate, some have said it can be the bank of solenoids under the glove books, just wish there was a way i could diagnose before spending money on a new bank
    99 VT Sedan
    Feb 2010
    This is the first vt i have owned
    Is it normal in a vt When you start the engine the air con takes a few seconds to come out of the dash vents????
    03 vy calais L67
    Moto X Champion!
    Mar 2009
    Townsville, QLD
    well when it on high it gets to cold so i turn it to low and then forget about it. and then it gets hot so i turn it back up to 2 or 3. then realise its on the screen.
    99 VT Sedan
    Feb 2010
    Quote Originally Posted by 11gothevt11 View Post
    Anyone have any more ideas??
    VT V8 Calais
    Mar 2007
  15. #15
    99 VT Sedan
    Feb 2010
    Take a look at this, my issue was the actuator
    How to change aircon actuator in VT
    Thanks heaps for the info great read
    Just a question how did you find out that this was the problem???????????
    Leaking air around this actuator?????
    So yours had same problem diverting to windscreen??
  16. #16
    VT V8 Calais
    Mar 2007
    I checked the other hoses first, I could hear a hiss coming from the actuator (losing vacume). Yep, had the air dirverting to the screen issue on throttle up a hill, hence the writeup when I changed mine
    50LTRv8
  1. been hit? what went though your mind?
    By jphanna in forum The Pub
    Last Post: 14-07-2010, 01:11 PM
  2. Another ricer that has lost his mind.
    By DARK SIDE in forum The Pub
    Last Post: 22-07-2009, 12:09 PM
  3. Vn has mind of its own!
    By White_Knight in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-03-2006, 09:27 PM
  4. Help VS with mind of its own
    By Hannah in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-04-2005, 05:21 PM
  5. Help VS with mind of its own
    By Hannah in forum General
    Last Post: 21-03-2005, 09:47 PM
