Results 1 to 18 of 18
Thread: How do I disconnect the warning beep for the handbrake?
    HSV XU6
    Mar 2010
    Gold Coast
    Default How do I disconnect the warning beep for the handbrake?
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Handbrake warning is very important. If you drive around with a partially engaged handbrake it will heat them up and destroy your brakes very fast, could also start a fire.
    Ronald Reagan (1986)
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    find the wire that goes to the handbrake-up switch and either earth it permanently, or snip it & leave disconnected - depending on if it's normally open or normally closed.
    HSV XU6
    Mar 2010
    Gold Coast
    Quote Originally Posted by VN_Luke View Post
    I just want to disconnect the bit that makes the beep that's all, the actual beeper part. I have had a good look but just cant find where they hide it, my car is a VT some one must know where it is as this is not the only thing that makes it beep!
    VLC86's Avatar
    VLC86 is offline ..stay N/A..
    VL Calais
    Dec 2009
    Quote Originally Posted by hakhawk View Post
    disengage the handbrake?
    Yes, that should do it
    World's slowest project
    Quote Originally Posted by hi_ryder View Post
    for entertainment purposes only, hi_ryder does not condone the murdering citizens on assumption of theft, or illegal firearms possession
    00 SS M6/79 chev Monza
    Mar 2005
    if they made it easy to stop the beep ,everyone with faulty airbags would
    1 remove the globe
    2 cut the wire to the beeper !
    I have never been able to find it and i removed the dash to replace the evap and heater cores !
    mwb235 Guest
    Quote Originally Posted by kaz777cars View Post
    AFAIK the "beep" comes out of a small piezo inside the dash cluster, which also emits other sounds like low fuel etc, and it can't be disabled. It may also be controlled by the BCM but i'm not sure.
    Maybe you'd need to snip the wire down near the handbrake lever itself? That's what's generating the signal that "tells" the dash cluster.
    HSV XU6
    Mar 2010
    Gold Coast
    Quote Originally Posted by mwb235 View Post
    I would if that was the only beep I was getting but the airbag and oil pressure is making it beep too!
    hakhawk's Avatar
    Jan 2005
    get the airbag and oil pressure problems fixed, and the beeping will go away! theyre both much needed warnings, not really something you want to disable
    mwb235 Guest
    You're getting other beeps too (and i assume lights on the dash cluster)? Does it play just a one-tone beep or multiple beeps (like a melody etc). If so you might need someone to look at it.
    Maybe your ABS module is faulty, it's a common VT/VX fault and causes multiple beeps/warning lights - do a search there's heaps of threads on this. There used to be a bloke on eBay who repaired ABS/TCS modules - you send him your faulty one and he sends another repaired one back (i.e. exchange). That was in late 2007, i haven't checked lately but he (and probably others) are likely still doing this.
    HSV XU6
    Mar 2010
    Gold Coast
    Like I've been saying all along I only want to disable/cut/destroy the beeper nothing more
    I do not want to pay any one to fix it the car is not worth spending a cent on so if anyone out
    the knows where that little beeper is let me know I don't need any solutions to the problem,
    but thanks anyway
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    its been said lol
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    HSV XU6
    Mar 2010
    Gold Coast
    well I pulled the oil light out and it doesn't beep on idle now so hopefully problem solved.
  15. #15
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Try using Ear plugs .
  16. #16
    mwb235 Guest
  17. #17
    VZ SV6 & a ZX6R
    Apr 2010
    Bathurst NSW
    I believe you mean 'Problem hidden' not 'Problem solved'
    As has been said, you cant just disable the beeper. Its not just a tiny speaker located somewhere that you just have to snip a wire to. If you dont want to spend a cent on this car, then just deal with the beeping. From the sounds of things and the fact you dont want to fix anything you wont have to put up with it long before the car shits itself big time anyways. Goodluck
  18. #18
    2003 VY II S-Pack 25th Anniversary
    Feb 2010
    Central Victoria
    yeh silly idea to stop it IMO, its telling you something is wrong so best idea is to fix it.. thats why its there
  1. stop that beep beep beep digital dash
    By murphy_51 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-09-2010, 07:04 PM
  2. Handbrake Warning Lamp Fail
    By 88GreenVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-02-2010, 08:14 PM
  3. BEEP BEEP BEEP - Bulb sensor keeps going off
    By anonymousmoose in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-12-2009, 03:28 PM
  4. Handbrake warning when turing right?
    By Torquative in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 03-03-2009, 07:05 PM
  5. Handbrake Warning Tone
    By ducatis in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-11-2006, 07:10 PM
