Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: Beginner looking for advice
    VT Acclaim S2
    Nov 2010
    Default Beginner looking for advice
    Hey all,
    Just recently turned 18 and got my first car, a VT Acclaim S2.
    Was looking for some advice on some standard modifications I should make to it before I try and do anything too drastic. I was thinking about putting some king springs on, because I don't want it too low, just enough to get rid of the space above the guard and the wheel.
    Thanks in advance
    VT SS 5.7
    Mar 2005
    Goulburn
    Hi mate, spend about $50 for a inlet manifold gasket kit and $8 for a can of mr muscle over cleaner,
    Pop your manifold off and give it a good scrub down over the years them v6 gather alot of soot and old oil and reduces the cars breathing.
    Real cars don't power the front wheels, they lift them
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    If you're keen, get some sand paper and polish up the intake manifold. Check the painting forum, I've got a thread going in there with some info. Be warned its a long tedius process.
    VT Acclaim S2
    Nov 2010
    ok thanks for the tips fellas. I'm not very fluent in technical language unfortunately, so I'm gonna scout these forums to see if I can figure out which parts are where, haha.
    Thanks a lot
    Nov 2008
    Smithton, Tasmania.
    Intake manifold is the bit that the has the throttle body. which attaches to the airbox.
    VT Acclaim S2
    Nov 2010
    thanks soop. also, when you said that it's a long tedious process, how long are you referring to? Hours or days?
    Thanks mate
    Nov 2008
    Smithton, Tasmania.
    Day's :P.
    I'm doing it all by hand and taking my time. But you could do it in a day if you started in the morning and worked like a dog. Its better if you just cruise it and have a few beers while you're at it.
    '94 VR Exec
    Feb 2010
    Wagga Wagga, NSW
    I'd give it a good clean all over, and then fix anything that's broken, and get some little things done like nice mats and seat covers.
    Maybe give it a good service depending on how long it's been, then look at something like a 2.5 inch cat back exhaust and wander over to MACE and check out some of their products.
    As for the springs, I went King Spring Lows, and its still pretty practical but looks and handles better. And buy a workshop manual, will come in handy for sure.
    VT Acclaim S2
    Nov 2010
    alright thanks soop, I'm looking into it as we speak. I'll keep posting here, if you're willing to give a newbie some more advice haha.
    sounds good flak, I bought some mats and covers for it but the clean all over sounds appealing. also, can you recommend any workshop manuals?
    thanks guys
    VL Commodore
    Dec 2008
    Hi,
    I'd begin by getting the car in good condition first, basically giving it a overall service, those should be your first modifications
    as it's best to have the car in good condition to start off if you plan doing any performance modifications, or any performance driving.
    Check the whole car inside/out. Oil, Oil Filter, Spark plugs and leads if needed. Do a coolant change
    and it's a really good idea to replace the radiator if blocked/damaged, takes experience to know what needs changing so it's a good idea
    to have a mate help you out.
    It's a VERY good idea to replace the fuel filter too. Clean throttle body and Idle Speed Control Valve
    Get the car up on all 4 wheels, or 2 at a time and check each wheel for freeplay and fix cause if excessive,
    worn bushes/ball joints and bearings constantly affect wheel alignment as you drive. Check the brakes and
    brake lines, check the handbrake and adjust if needed
    If Auto give the transmission a fluid+filter change. Check all 4 wheels when up in the air
    for any play and rectify the problems.
    Check the belt and pulleys, they do get worn over time.
    King Lows are ok, but if you want to get extra low, consider getting a strut/spring combo, or even coil overs if you like as it's important to have
    a good spring/shock combo, it's ok if your only lowering a bit.
    Service Manuals - Gregories is your best bet 2nd to the GMH one which are hard to get a hold of. Stay away from Max Elleries as their "wiring diagrams" are rubbish,
    but they seem to have more pages. I'd just stick with the Gregories and read it as they are helpful.
    When you get the car in a good condition and you want to begin doing performance mods here are some suggestions.
    Higher ratio roller rockers from FIT Performance... check out their website
    Cold Air Intake will help out a bit
    Heat insulator spacer for inlet manifold... apparently gives a bit more power.
    Then you can get a Tuned memcal from Greenfoam or Delcowizz who are on this forum
    Extractors and Exhaust.... it's a good idea to do lots of reading on the subjects of extractors and exhausts before chosing, see what people run and whats best, the V6's
    can have a horrible sound if you don't get the correct setup which I'm sure we've all heard. If there are good off the shelf exhausts for your car, you could buy one
    and install it yourself.
    '94 VR Exec
    Feb 2010
    Wagga Wagga, NSW
    Cool, and yeah a good clean will make a big difference...which reminds me that I really need to wash mine haha.
    I bought the Gregorys one, which I'm pretty happy with. Your local SuperCheap Auto/Autobarn/Repco etc should have one in stock.
    VX Acclaim S2
    Jul 2006
    Ringwood, Melb, VIC
    just do yourself a favour and stay legal, i went SL King Springs on the front and SSL King Springs in the rear, got away with it for 2 years, but finally got pulled over, defected and fined $300, then cost me a further $250 to put SL's into the rear to bring it back to legal. Trust me, do it right...ONCE!
    Infanti VX S2
    Fat people are hard to kidnap!!!!!!!
    Nov 2008
    Smithton, Tasmania.
    Quote Originally Posted by Infanti View Post
    Cannot emphasise that enough!!!
    Especially for a young bloke.
    2DIE's Avatar
    2DIE is offline ONEDOLLAHOLLA
    97 Acclaim
    Feb 2008
    South Aus
    Try having a look here, only just started working on this to keep myself kind of a history of what I want to do and what I have done. Yeah its crappy site but its where I keep prices and ideas so I dont forget later.
    https://sites.google.com/site/vtacclaimv6/
    As you can see if you take a look most of them are just for looks.
    On the "Under the hood" page I would recomend the 3 MACE products.
    And on the "Exhaust" page I would have a look at the cat back, search "VT cat back" on ebay and they are around $165
    Lowering the car is more expensive than just springs, you will also need struts and camber kits and you will be looking at about $1000 at a guess unless you want to buy tyres twice as often and drive you car around with worn shocks.
    Best RPG ever
  15. #15
    1998 HSV VT GTS 5.7 Stroker
    Mar 2010
    Tauranga NZ
    If you're anything like me and like having a clean engine bay,you could try painting.This is the end result at my first attempt.Turned out sweet!!!
  16. #16
    VT Acclaim S2
    Nov 2010
    Wow there's been a few replies since my last glance, I'll have to reply in sequential order :P
    @Z2TT, thanks heaps for all the detail you've gone into, I copied and pasted into a word document haha. It recently had it serviced but can get my uncle to have another look at it. A lot of the stuff you've mentioned is what I'll probably be looking at doing within the next 12 months, so thanks a lot for all of that.
    @Flak, yeah I'm going to go down within the next week and pick up the Gregory one for commodores. As my VT is a series 2, will this book be suitable for me? Gregory's Car Manual - 273 - Supercheap Auto
    @Infanti, sorry to hear about the defective notice mate, but I'll take your words of advice haha
    @Soop, haha yeah, I'll take that on board
    @2DIE, yeah I heard about the camber kits and the like, so I had a chat to my cousin a few weeks ago when I mentioned lowering it. He suggested the King Lows, because he can install them and do the necessary adjustments in order to make them work, that's what made me look at them. Also, thanks for the website. I'm having a look at it tonight.
    Finally,
    @1998GTS, that looks sweet man, probably a bit advanced for me at the moment but definitely something that looks worth the effort.
    Thanks for the replies fellas
  17. #17
    Nov 2008
    Smithton, Tasmania.
  18. #18
    VT Acclaim S2
    Nov 2010
    Is this in relation to the intake manifold?
    If so, do I need to pair anything with the sand paper to get a better result, or is sand paper better on it's own?
    Also, can you link me to your painting thread? I can't find it.
  19. #19
    Nov 2008
    Smithton, Tasmania.
    you could use a little water if you want. Might make it easier on your hands.
    Just start coarse and work your way up.
    I started with 220 - 320-400-600-800-1200-1500-2000 then autosol.
    So far i've spent 6hrs with the 220 grit because the castings on my rocker covers was horrible. If you want to buy another intake manifold and send it my way I don't mind polishing it up for you.
  20. #20
    VT Acclaim S2
    Nov 2010
    Ah ok fair enough, may have to try that out. I appreciate the offer mate, I'll see what happens. I wanna try it myself first, try and learn what I can, but in the likely event that I experience difficulty, I'll give you a yell, haha.
  21. #21
    Nov 2008
    Smithton, Tasmania.
  22. #22
    VL Commodore
    Dec 2008
    How much does Autosol cost and how large is the pack/tube/bottle etc it comes in?
    Also the plenum spacer that spaces that top cover of the plenum, how does that increase performance?
    I can understand about the one for the actual manifold to head, but what about the top cover one?
  23. #23
    VT Acclaim S2
    Nov 2010
    Also, thought I better ask. What exactly does polishing the intake manifold do for your car?
  24. #24
    Nov 2008
    Smithton, Tasmania.
    Makes it look good!! hahaha.
    Autosol cost about $10 for a 250g tube, but it goes ALONG way, you don't need much of it at all.
    I guess the idea behind the plenum spacer is increased volume, perhaps it helps with the air flow into the intake runners, I wouldn't know I've never looked into the V6 stuff.
  25. #25
    '94 VR Exec
    Feb 2010
    Wagga Wagga, NSW
    Provided its any V6 VT between 1997 and 1999 I'd say so. I don't imagine there'd be that much difference between Series 1 and 2 but I don't know a whole lot about the VT's. You can always ask when you go in and see them.
  1. new headunit install IN VX? complete beginner
    By bignath in forum Car Audio
    Last Post: 17-02-2010, 06:56 PM
  2. Beginner Bonsai tree
    By greenvs in forum The Pub
    Last Post: 21-06-2009, 01:39 AM
  3. BEGINNER n00b question - VX modding
    By theartofnecro in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-03-2009, 11:11 AM
  4. advise for a beginner
    By 16 vk boy in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 20-06-2006, 06:46 PM
  5. help driftin an auto ute for beginner?
    By storm89 in forum General
    Last Post: 31-03-2006, 06:16 PM
