Ive got a VX exe wagon late 2000 Model.
The problem I have with it atm is that it starts great no problems there and then out of the blue it carries on like the battery is completely flat nothing happens and I require a jump start and then no problems again for 3 weeks or more. The charge light is not coming to signal of problems with alternator. Ive only owned the car for 3 months its got 192,000 on the clock with full service history nothing a miss except for this annoying problem someone has suggested its got 1 dead cell in it but wanted to check to see if this sounds right
yer sounds about right. i had the same problem happen to m a few months ago. however as mine started to die it gradually got harder to start like the battery still held a little charge. but yer sounds like a dead cell.
Make sure you have clean and tight connections at the battery terminals, alternator and earths. Go to an auto electrician and have you battery tested, they can tell you in a couple of minutes and usually don't charge much, if at all.
MY RIDE
i think repco has a free battery test try there
