Results 1 to 25 of 25
Thread: VT V6 overheading
    VT Commodore Executive 9C1
    Aug 2009
    Croydon Hills, Victoria
    Default VT V6 overheading
    Hi guys,
    i was stuck in some traffic today for as little as 20mins and my temp needle went through the roof, normally sits at around the 1/4-1/3 mark yet it rose to as far as 7/8, the temp on the digital gauge in the eng mode said it was sitting at around 115 C, needless to say i did the smart thing and turned it off to stop the temp rising, when i got to work the radiator was empty, and i mean empty, it drank about 5L of water and then i let it sit all day, got back to it this arvo and it was only about half full, put another 3L or so in it. Now im at home after a 20min drive from work and its empty again, i cant see any water leaking, there is no water in the passenger footwell (heater core) but i am yet to check the oil due to how warm it all was...would really love some help on this as i am completely stumped as to what to do next.
    Thanks
    Matt
    Growing Old is Mandatory...Growing Up is Optional!
    My Ride http://forums.justcommodores.com.au/...utive-9c1.html
    VT
    Apr 2005
    QLD
    Check the cheapest things first, look for coolant spray around the engine bay, check all hoses and it might pay to have the radiator pulled, checked and cleaned.
    If the issue is not there, i would say it is leaking into the combustion chamber via a stuffed gasket or a crack somewhere.
    Check the oil and let us know
    VT Berlina
    Oct 2010
    Aug 2009
    Quote Originally Posted by BPX-31H View Post
    Mine did the same today, got it towed it was the heater tap,
    LOL the first warm day of the summer and our cars crack the shits, where is the heater tap??
    VT
    Apr 2005
    QLD
    Up on the firewall mate, look for some hoses feeding into a black plastic junction.
    Should have a cable connecting to it as well, coming from inside the cabin
    I think thats right lol
    Aug 2009
    well ive run some new coolant through it, checked the oil and there was no sign of water in it, dad and i checked every single hose within the engine bay and have not found a leak, both driver and passenger footwells, there is no coolant spray in the engine bay, but a very strong smell of coolant, its funny my dad noticed all these things about my car that have changed since he owned it, cause i drive it every day i have gotten use to them, such as the coolant smell from the heater core and the fact that it idles at around 400RPM after the tune it had at the last service...anyways, im going to try and ring my mechanic tomorrow and take it to him in the afternoon for a pressure test and check.
    VT spac super6
    Nov 2008
    Riverton sa
    Gona vote for heater tap... wrap it in paper towel somethings it can only leak a fine spray at full temp, which will instantly boil off leaving no signs..
    Aug 2009
    Quote Originally Posted by HARVZ-6 View Post
    that explains the sudden jump in temp as soon as it got to full temp....thanks mate!
    VT Berlina
    Oct 2010
    Yer I reckon heater tap, I got large amouta of coolant smell, at first I was like fml is my ca gonna handle summer!
    VX 'S' S1
    Apr 2005
    South East,Victoria
    +1 for heater tap . they get brittle with age . They leak and the coolant runs back towards the firewall and is hard to see . Clean the area aroung the tap so you can see if it leaks . A new one costs about $50
    VT Berlina
    Oct 2010
    yeeep! all over the framework, and even lifted paint up with its heat im guessingg..
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    pressure test it and confirm is a heater tap
    but is made off the same material as your radiator side tanks could be that too,
    is not uncommon to have multiple leaks because all plastic in the cooling system is the same and under the same pressure!~
    i wont guess on cooling systems in these because overheating or low oil is the 2 killers of these motors
    +1 pressure test first
    Aug 2009
    well i got the mechanic this arvo, pulled over twice on the way...took me an hour to get from bayswater to lilydale...if anyone knows its really only about 20mins all because temp gauge kept climbing and because its an iron block it takes forever to cool down...so far in 2 days i have put around 10L of water in the thing....praying its not something chronic or something expensive...what really annoys me is i have looked after this car rather well...i only checked the radiator and levels about 2 weeks ago....GRRRR
    03 vy calais L67
    Moto X Champion!
    Mar 2009
    Townsville, QLD
    when my heater tap went it didnt start off with a fine spray....it went from not leaking to steam coming from the bonnet and dumping 10L of coolant on the road no mucking around here! lol
  15. #15
    Aug 2009
    Quote Originally Posted by drift-it View Post
    so far thankfully it hasnt done that yet...i think i may have just caught it in time...if it wasnt for the damn train at bayswater station getting stuck over the road i wouldnt have noticed it! it may have made me late for work...but 10mins late is better than a new engine cause i cooked one...
  16. #16
    dylanstone's Avatar
    dylanstone is offline tsu tsu tsu tsu
    3.8L 1997 VT executive
    Feb 2010
    sydney, eastern suburbs
    its the heater tap, mine literally did the exact same thing where you cant trace any leak
    get ur mechanic to bypass the heater tap or core not sure which one it was and feed the hose that exits the left of your engine in a "U" straight back into the same side below where it exits. it costs like 1000 plus or somes**t to repair so thats why i get them to to that, been running for 6 months fine
    up to you though lol
    * 1997 VT executive
    * 2.5 inch Lukey catback
    * Lowered on Munro shocks Pedders springs
    * Fusion 1000 watt amp & Kenwood 12 inch sub & head unit
  17. #17
    Aug 2009
    Quote Originally Posted by dylanstone View Post
    ive been meaning to do the heater core myself, they are a bitch of a job and i havnt got any money atm....maybe i will just take it off the cost of what i owe dad for his car...cause the heater core has been on the way out for about 3 years....he was to tight to fix it...now he will have to deal with it!! :P
  18. #18
    09 VE Clubsport R8 317/ VT Commodore exec 5 SPD
    Jul 2010
    melb
    how long do heater taps usually last cos of course mines doing the same thing atm (rises in temp rapidly and no coolant left but no leaks). i replaced my heater tap about 10 months ago
  19. #19
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    pressure test sytem or your wasting your money worth the cost of having it diagnosed then replace the failed parts yourselves...
  20. #20
    Aug 2009
    well this is the first time its ever been done in the 12 years the car has been in my family...so first one since new...its done just on 215xxx kms
  21. #21
    dylanstone's Avatar
    Feb 2010
    all i know is their made outta shitty plasic and cost a bit over a grand to repair as the dash and every thing needs to be ripped out ( i think )
    * 1997 VT executive
  22. #22
    Aug 2009
    Quote Originally Posted by db_notso View Post
    i would but i am in the middle of exam time, i need the car for a work trip next week and i just dont have the time to do it....im always out and dont get much time to sit around apart from at night like this when im normally studying
  23. #23
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    in that case...
    cold motor take your cap off radiator
    fill to top
    take engine cover off
    slightly undo bleed nipple at engine side of top radiator hose (is a flat blade screwdriver for this)
    fill radiator (may need to wedge coke bottle with tape around lid thread and bottom of bottle cut off, in it to be higher than bleeder nipple)
    keep filling it until only liquid comes out ( if none comes out then you need coke bottle method)
    close bleedr nipple
    put cap on radiator
    start engine
    get a torch and as engine heats up (gets under pressure) look at the heater tap right hand side of engine bay with four hoses coming out of it
    also look at BOTH radiator side tanks
    also look at cap under edge
    also look at water pump on front of motor or just below it
    if the fans come on (5 ten minutes) and none of the above are leaking (e.g. see water or stain)
    rev the motor at the cable on the engine
    as revs go up watch each of the above again for any cracks drips etc
    normally this backyard methjod is enough to find the leak if not
    might be heater core (rare) or valleys (rare) or auto cooler if its the auto cooler your transmission fluid will be milky (check on dipstick)
    hope that helps
  24. #24
    Aug 2009
    in that case...
    hope that helps
    auto trans completely forgot to check that...it does have a cooler on it (ex ambo car)...its too late now its at my mechanics....im just going to pass the fee on to dad anyways...just take the cost off what i owe him!!
    thanks for your help mate, i will keep this in mind for future reference
  25. #25
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    too easy havent been able to get on here for a while so maybe next time bud
