guys I've heard some ppl swapping their maf sensor from standard v6 vx to an ls1 vx v8 claiming that it gives more power and fuel economy and less air restriction....
is this is true?????
its different range sensor and would affect air fuel ratios not recomended without a tune in which case you would go mafless anyway
thanks mate i did went 2day and found 1 at wreckers but the guy over there insist it wont fir into my car... its different assembly...
ls1 you would be better off saving for a good mafless tune then put a massive intake on it
rarther than messing with the lifespan of your motor...
