Results 1 to 6 of 6
Thread: Is it too hard....
    RichoKidd's Avatar
    RichoKidd is offline Obese Commodores
    VT 3.6 2000 Executive
    May 2010
    Perth, WA
    Default Is it too hard....
    ....to wire up an Oil Press. Water Temp & Volts Meter gauges under my H/U in my VT? Has anyone done it before?
    Any help would be much appreciated. I know it costs a bunch to get it done with an Auto Sparky so Im trynna save money by doing it myself
    SUPPORT AUSTRALIAN HIP-HOP
    Vx s
    Oct 2010
    Glenroy
    there is a thread in the how to section (i think) with a write up on how to do 2 gauges in the little space underneath the HU very detailed. that should help ya along. good luck
    Now we have moved onto quantum physics and popcorn.
    My vx s
    Mick1988's Avatar
    Mick1988 is offline W.A. Cruise Moderator
    Too many to list......
    Apr 2008
    Perth, Western Australia
    You would have to tap in to the wiring near your ECU which is down the passenger side kick panel. What pins are what I couldn't tell you off the top of my head but I do have a wiring diagram here I can look at once I've woken up a bit more. I'd assume you just tap into the +ive from the oil pressure sensor, coolant temp sensor and your battery.
    VX2 Executive Sedan - 3.8L Auto (for now)
    VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)
    VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
    jakbob's Avatar
    jakbob is offline Lighten up.
    VX SS, VC L, VK Vacationer
    Dec 2008
    Why would you put a coolant gauge in? There is already a temp gauge in the dash cluster. I'd just go volts and oil pressure. You may have to install a new oil pressure sender, I don't know if the factory one is a variable resistance one for measuring the pressure or just an on/off sort for running the idiot light.
    Four commodores and counting.
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    For the oil gauge, most people just run a T-joint to run both pressure sensors.
    Ronald Reagan (1986)
    RichoKidd's Avatar
    May 2010
    Perth, WA
    I got gauges off ebay and they all come with senders. Its more for look then anything else
  1. Installing hard top, hard lid or hard cover?
    By clapnrobem in forum General
    Last Post: 12-10-2011, 08:36 PM
  2. how hard can it be
    By ybl8te in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-08-2010, 06:20 PM
  3. wtb:- VU UTE HARD LID
    By timbo_001 in forum Swap / Wanted to Buy / Trade
    Last Post: 18-05-2006, 06:53 PM
  4. how hard is it to get a ute
    By xu1au in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-05-2006, 09:54 PM
