Results 1 to 7 of 7
Thread: VT brake light bulb
    1998 VT Acclaim
    Nov 2010
    Default VT brake light bulb
    Very basic question. My 1998 Acclaim VT right brake light globe is not working and I need to replace it.
    1. What bulb do I buy (from supercheap auto etc?) - is there a size or a number?
    2. How do I replace it?
    Yup - I'm a newbie!
    Mick1988's Avatar
    Mick1988 is offline W.A. Cruise Moderator
    Too many to list......
    Apr 2008
    Perth, Western Australia
    It's just a standard double filament globe. Easiest thing to do is remove your globe, take it with you to Supercheap and visually compare it.
    To remove it, open your boot. On the side of the tail light near the boot seal you should see two screws. Undo those screws and then you should be able to pop the light out. The globe holder just unscrews from the tail light and then you just unscrew the globe from the holder.
    VX2 Executive Sedan - 3.8L Auto (for now)
    VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)
    VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
    coasty's Avatar
    coasty is offline the voices told me to
    vz equipe & vt berlina both v6
    Feb 2008
    kanwal nsw
    just go in and ask for a brakelight bulb for a commodore. they should know. when you undo the light assembly pull straight back as there is a clip on the side opposite side to the screws
    i do as the voices tell me
    Commodore M6
    Jul 2010
    East Coast
    two screws on the boot edge
    a friction knob on the bodywork side... use some strength to pop it out
    easy as
    1998 VT Acclaim
    Nov 2010
    Thanks a zillion - followed instructions as above:
    1. Removed and inspected bulb (Thanks for the info!)
    2. Got a brake light bulb from a gas station
    Had my brake lights working that evening!
    Only problem is I did NOT change the bulb - guess the removing and checking took care of some loose connection.
    Duh!
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    It's a good idea to carry in the glove box spare globes to cover all the external lights. So if you are out and one blows, you can replace it before you get pulled over and have a defect notice put on your car.
    Happened to me last week, got pulled over by police and told my brake light was not working, so I promptly replaced it on the spot without any defect being issued.
    1998 VT Acclaim
    Nov 2010
    Sounds like a good idea!
    What happens if you get a defect notice?
    Quote Originally Posted by pablo View Post
  1. Changing brake light bulb problem
    By bazza13 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-10-2010, 03:38 PM
  2. tail/brake light bulb failure
    By 2greedy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-07-2006, 07:15 AM
  3. 'Rear light bulb failure' warning light
    By Misaprop in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-04-2006, 03:07 PM
  4. brake light bulb replacement.. how?
    By bundaberger in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-04-2006, 06:38 PM
  5. Vx Brake Light Bulb
    By Ross557 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-06-2004, 04:21 PM
