Results 1 to 3 of 3
Thread: VT Climate Cntrl
    VR Acclaim 94 S2
    Mar 2009
    Question VT Climate Cntrl
    Hi All
    I have two blown bulbs in my climate control, 1 is on the screen and the other is on the switch panel. Is it as easy removing it and replacing the bulbs or do u need to replace the whole unit? Also are the mode buttons for the instrument cluster supposed to be illuminated? Any help would be great.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    The globes can be purchased from Holden, so they are not cheap. They are easy to replace once you have removed the climate control panel, which means removing the dash surround first. The mode buttons do light up so probably a blown globe there too.
    MY RIDE
    VT 3.8ltr Berlina Next Car: VZ Calais or VY SS
    May 2010
    i would imagine the same type of setup as in behind the dash cluster.
    once apart it should be as easy as unplug and plug in a new globe.
    let me know how you go maybe inbox me any hints/tips, i need to change one in behind the mode panel
    ive got half my dash pulled apart fixing my airflow problem with the Actuators.
    with the help from accentstencil i might add ive finished that little project , cheers again
LinkBacks (?)
  1. 21-10-2011, 08:53 AM
  1. climate control,how does it work need to know for climate control conversion
    By bhopper in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-07-2010, 12:49 PM
  2. vy acclaim hard to change manual climate to electric climate???
    By tyrone in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-08-2008, 07:43 PM
  3. climate fan
    By ad45 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-01-2008, 10:24 PM
  4. Indicator/cruze cntrl stalk
    By vsv8berlinawag in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-04-2006, 08:40 PM
  5. Headlights problems, Hard Starting, Cruise Cntrl
    By DUMPD_VP_CALAIS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-08-2004, 07:12 PM
