Results 1 to 7 of 7
Thread: coolant leak???
    vt acclaim
    Jul 2009
    Cool coolant leak???
    hey guys found a leak thismorning it appers to be coming from behind the middle drive cog at the fron of the engine fill up rad and it pours out for a bit then it trickles till a point then stops hoping some on can provide sum ideas dont think its water pump etc too high up for that????????
    VY2 Calais L67, VT Berlina L36
    Oct 2009
    Toowoomba
    the "middle" pulley in the engine is the waterpump??? Maybe circle the point in the linked image below that indicates where the leak is??
    http://carphotos.cardomain.com/ride_...0001_large.jpg
    Dec 2009
    Quote Originally Posted by spectral View Post
    What sort of car is that engine in?
    Oct 2009
    Toowoomba
    vt acclaim
    Jul 2009
    vt acclaim
    Jul 2009
    VT 3.8ltr Berlina Next Car: VZ Calais or VY SS
    May 2010
    Check the O-Ring seal on the hose at about 10 o'clock to the water pump.
    runs in behind the tension pulley
    marked with red arrow
    or check if not leaking below this- marked with red circle
  1. VX Coolant leak from Coolant Reserve?
    By anarklov3r in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-09-2010, 09:50 AM
  2. VT Coolant leak....
    By jwoods997 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-04-2010, 03:02 AM
  3. VS Coolant Leak
    By Harvs82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-04-2007, 10:05 AM
  4. Coolant Leak
    By U2Bono in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-11-2006, 05:23 PM
  5. odd coolant leak
    By tsalad in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-09-2006, 08:33 PM
