Results 1 to 7 of 7
Thread: VT reverse lights not working
    VP
    Nov 2010
    Default VT reverse lights not working
    I've recently picked up a VT wagon and when put into reverse the lights don't go on. The globes are all fine.
    I read a 'How To' guide on replacing the inhibitor switch, but this guide was for the VS model. I've taken out the centre console and can't seem to find the inhibitor switch. Does the VT even have an inhibitor switch? If not, any idea on what the problem would be?
    Here's an image of what I'm up to. Any help is greatly appreciated.
    VP
    Nov 2010
    DLFHUB666's Avatar
    DLFHUB666 is offline Got Milk ???
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    cant help on the inhibitor switch. but have you checked the reverse light fuse?
    Take it easy...But do take it...
    Do not argue with an IDIOT.
    He will just drag you down to his level an beat you with experience
    Some people take me the wrong way, Like smacking up Marijunna.
    vs commodore
    Oct 2009
    Tamworth NSW
    If its anything like the VS type,its gonna be right at the bottom of the shift stick under that black plastic surround around the gearshift there in the pic.The switch should have some electrical wires going to it that you will see there somewhere..You would think someone on here would know exactly where it is and be able to help you..I only own a VS,so Im not 100% sure.
    Vy Ute, V6, Manual
    Mar 2009
    East gippsland Vic
    It could be the reverse light switch. Is it a manual? if it is the switch is located on the drivers side of the gear box up the top. If you short the two wires out and the lights come on then your switch is most likely ****ed , i think they're about 65 bucks from holden. Not to sure about auto could be the same but ive got no idea.
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    switch is on the side of the gearbox on vt onwards.
    black box around where the shift linkage goes inside the box.
    VT II Commodore Station Wagon
    Feb 2011
    Western Australia
    where is the fuse
  1. Reverse lights stopped working after car was off the road for 2.5 months,how do i fix
    By shanhsv in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-08-2010, 11:54 AM
  2. reverse tail lights not working vs ute
    By vstfeas in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-05-2010, 06:25 AM
  3. Reverse lights not working?
    Last Post: 10-01-2010, 04:59 PM
  4. Reverse lights not working on reverse
    By macca_223 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-01-2010, 11:02 PM
  5. VS Acclaim Wagon Reverse Lights not working
    By djvass in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-05-2009, 04:43 PM
